Givi top boxes
Discussion in 'UK Motorcycles' started by Catman, Dec 23, 2006.
  1. Catman
    Catman Guest
    Well, looks like I may as well keep the Triple. I've got used to the
    commute, and I still like the bike *loads*. So apart from the headlamp
    mod I have one other thing to do: Top box [1]
    Looking at the Givi site, they only apparent difference between the
    Monolock and Monokey systems are the 'weight'. So questions for anyone
    that has sued them
    1) Is Monokey preferable to Monolock for any other reason?
    2) Are these things waterproof?
    Are there any other brands I should consider?
    TIA
    [1] Yes, I know it will hardly help the aesthetics, but at least I can
    swap the pillion seat for the hump when I'm not using the luggage.
    www.cuore-sportivo.co.uk
  2. Catman
    SteveH Guest
    Monokey is generally used for the full pannier / top-box sets. They use
    incompatible fixings.
    However, I discovered that, if you have a Monolock top-box (as I do - a
    Givi Simply), you can bolt the mounting plate for it to a Monokey system
    'Wingrack' and can also change the lock on it so it matches that of the
    side cases.
    My top box has never leaked, however, the panniers have. I reckon it's
    more to do with the mounting position rather than the boxes being
    waterproof.
    Kappa boxes are interchangeable with Givi boxes and frames and can be
    significantly cheaper.
    SteveH, Dec 23, 2006
  3. Catman
    Tarby777 Guest
    I've got Givi E21 panniers and have been out on the bike in serious
    absolutely-bucketing-down rain several times this year. Nothing got
    even remotely wet...
    Tarby
    Tarby777, Dec 23, 2006
  4. Catman
    Catman Guest
    Indeed, ta
  5. Catman
    Catman Guest
    So cheaper is fine, they should be pretty waterproof, and Kappa is even
    cheaper
    Ta
  6. Catman
    muddy cat Guest
    I think Kappa is made by Givi.
    muddy cat, Dec 23, 2006
  7. Catman
    SteveH Guest
    I have a Givi 'Simply' top-box and plate bolted to a Wingrack using
    Kappa side cases. All-in cost was quite significant, but I saved a fair
    bit by getting a s/h wingrack (had to buy a new mounting kit, though),
    Monokey top-box and Kappa side cases.
  8. Catman
    SteveH Guest
    I meant, Monolock, obviously.
  9. Catman
    Likewise.
    I've ridden in torrential rain with Givi luggage mounted as top box and,
    many years ago on a VFR, E38 panniers. Never leaked.
    I currently use an E48 Monokey as a topbox on a Monorack fixture.
    I've no idea what the Monolock stuff is like.
    wessie, Dec 23, 2006
  10. Catman
    Catman Guest
    Ta
  11. Catman
    Gyp Guest
    My bit of advice (other than buy Givi, they do what you want them to) is
    to ask who has what spare before you open your wallet. The last time I
    delightedly mentioned that I'd got a Givi box from ebay, half a dozen
    ukrmers popped up with a cheery "oh, you should have said..."
    Gyp, Dec 23, 2006
  12. Catman
    Gyp says...
    I have a Givi Monorack top-plate going spare, if I can find that Oirish
    **** Petrolcan and nab it back, and if anyone else wants the ZZR1100D
    mounting arms that it's attached to they're welcome to them.
    Lozzo, Dec 23, 2006
  13. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    If you find him, get him to give me a shout would you?
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer as featured in
    Performance Bikes and Fast Bikes
    Wicked Uncle Nigel, Dec 23, 2006
  14. Catman
    muddy cat Guest
    I have a pair of Givi E41 sidecases going spare.
  15. Catman
    Wicked Uncle Nigel says...
    Will do, Colonel
    Lozzo, Dec 23, 2006
  16. Catman
    Catman Guest
    Good point. TBH I'm looking at £40 for a brand new one from ebay, so
    I'm not overly bothered. Topic changed just in case though :)
    Catman, Dec 24, 2006
  17. Catman
    Catman Guest
    Probably a bit of a sod to fit on the Triple, and would make it rather
    wider, no?
    Otherwise I would.
  18. I've got a decent Rickman g/f topbox in Wonderful Wickman White if you
    want.
    The Older Gentleman, Dec 24, 2006
  19. Catman
    any of the E** Monokey sidecases (aka panniers in English) can be used as a
    topbox with appropriate fixtures.
    Postage from Arniestate might be a bit of a fucker, mind.
    wessie, Dec 24, 2006
  20. Catman
    deadmail Guest
    *whoosh*
    deadmail, Dec 24, 2006
