Apologies if this sounds a bit of a dumb question, the answer is probably obvious if you have used Givi... 1. Is any able to confirm that any Givi Monokey top box will fit directly onto a Givi Monokey rack - without needing a separate adaptor plate? 2. Does the same apply to the same luggage when mounted as side panniers on a Wingrack 2?
