Gift suggestions needed
Discussion in 'UK Motorcycles' started by TMack, Oct 31, 2009.
  1. TMack
    What did you expect for €62,300.00-€105,000.00 per week.
    CT, Nov 2, 2009
    #61
  2. TMack
    I saw it in the cinema (with Ogden, FFS) and pretty much the whole
    time, the entire audience were laughing.
    darsy, Nov 2, 2009
    #62
  3. TMack
    Were you all stoned then?
    Ace, Nov 2, 2009
    #63
  4. TMack
    Simon Wilson Guest
    That looks quite small 'taters compared to the one that was parked up[1]
    watching Sunday's GP.
    [1] The only one that was parked sideways afaict. There seemed to be
    only two or three people spectating[2] from it.
    [2] Necking Cristal and troughing Beluga caviar no doubt.
    Simon Wilson, Nov 2, 2009
    #64
  5. TMack
    boots Guest
    I had a go there a couple of years back, you're perhaps pushing your
    luck on the weather front. June is apparently one of the better
    months.
    boots, Nov 2, 2009
    #65
  6. TMack
    'bout the same. It was one of the first videos [1] I saw - along with
    Creepshow [1].
    I thought both Max films were great - but I was about 12 or 13 at the
    time. I still think they're great.
    [1] Toploader go!
    [2] I want my cake!
    sweller, Nov 2, 2009
    #66
  7. TMack
    Domènec Guest
    <FBG>
    Which reminds me of a nice comparison between the Yamaha Diversion 900 and
    the French navy flagship aircraft carrier, which appeared once in
    fr.rec.moto. (Paging Veggie Dave le bandedesinard for translation)
    Parental advisory: Explicit Frog lyrics.
    Autor:Dr NO (XJR) ()
    Asunto:[comparatif] 900 div et porte-avions
    Grupos de noticias:fr.rec.moto
    (This is the only article in this thread)
    Fecha:1999/09/29
    Mathias Mercier a écrit dans le message
    AARRRDE A VOOOOUUUUUUS
    sur ce point je peux vous aider
    Le poids a sec est à peu prêt le même, mais c'est vrais qu'une fois tous les
    pleins faits, la div est avantagée car elle ne transporte ni eau douce ni
    carburant aviation . Les moteurs sont tous deux des water colled Au démarage
    la div se montre plus vive avec son cardant alors que les deux hélices du PA
    l'emporte tranquilement jusqu'a ses 32 noeud de vitesse maxi, ce qui est peu
    prêt celle de la div .
    En revanche le PA vire beaucoup mieux que la div, sur place en fait, pour
    peu qu'il ai un remorqueur de 2500 cv à l'AV et à l'AR .
    En virage donc la prise d'angle est plus iumportante sur la div, même avec
    30° d'angle de barre j'ai jamais réussi a faire toucher les genoux (par
    contre j'en ai fait gerber plus d'un).
    Pour ce qui est des colories celles de la div sont un peux plus jolie mais
    au moins le "gris Marine Nationale" cache astucieusement les chiures de
    mouettes et les moucherons, mais dans les deux cas la devise est la même :
    "peinture sur merde = propreté" ;o)
    l'accessibilité mécanique est meilleur pour le "géant des mer" (je l'aurai
    bien appelé "grosse vache" mais il pourrait y avoir confusion) :
    pour changer une pièce du moteur de la div il faut tomber les flancs de
    carénage long et fastidieux) alors que sur le PA il suffit simplement de
    découper deux trous de 5m x 5 m dans le pont d'envol et celui du hangar pour
    sortir la pièce (véridique) et en plus le PA il flotte, lui
    Sans oublier que l'antivol du PA est bien plus efficace que les U starndard,
    il se compose d'au moins six cables aciers de 5 cm de diamètre, et il ne
    faut guère que 2 heures et une bonne trentaine de boscos pour le mettre en
    place
    alors quel est donc l'intéret du porte-avion par rapport à la div ? il est
    lent, il angle pas en virage, il se traine partout ailleur,pour se faufiller
    dans les embouteillages c'est la galère je parle même pas du stationnement);
    c'est vrais, mais en revanche le premier couillon qui te déboite dessus sans
    cligno ou rétro, tu as le choix pour l'allumer : canon de 100 mm, missiles
    "crotal", super étendart ou encore plus vicieux : la chasse d'eau (ben ouai
    sur un PA c'est le
    "tout à la mer")
    ;o))
    tien puisqu'on accepte les gold et les div pour le calcul du coef, pourquoi
    pas les porte-avions : ça me ferait un coef de 360 546,29 !!!
    indétrônable avec mon Clemenceau
    voici les chiffres : poids a sec : 22 000 T
    réservoir : mazout 3600 T
    : gazoil 207 T
    : carburant avion 2000 T
    : eau douce 2100T
    soit un poids de 29907 T pour une hauteur de selle de 40m
    qui dit mieux
    ;o)
    V
    Dr NO (The XJR Family)
    affalez la GRAND VOILE pour répondre au bosco
    Domènec, Nov 2, 2009
    #67
  8. TMack
    "both"
    darsy, Nov 2, 2009
    #68
  9. TMack
    Veggie Dave Guest
    See? SEE? Slang!
    Er, what does it mean?
    Veggie Dave
    http://www.iq18films.co.uk
    "To assert that the earth revolves around the sun is as erroneous as to claim
    that Jesus was not born of a virgin." Cardinal Bellarmine
    Veggie Dave, Nov 2, 2009
    #69
  10. TMack
    Third one doesn't count.
    #70
  11. TMack
    Turnerist!
    darsy, Nov 2, 2009
    #71
  12. TMack
    The first episode of the new series was possibly one of the single
    funniest things I've ever seen.
    ogden, Nov 2, 2009
    #72
  13. TMack
    Pfft.
    While I remember, Children In Need is on the 20th. Strikes me as a good
    night to hit town for beers.
    ogden, Nov 2, 2009
    #73
  14. TMack
    I'm much the same about the Cannonball Run movies.
    Doesn't stop them being basically shit, mind.
    ogden, Nov 2, 2009
    #74
  15. TMack
    fuckity-yeah.
    darsy, Nov 2, 2009
    #75
  16. TMack
    got it lined up to watch tomorrow.
    darsy, Nov 2, 2009
    #76
  17. I loved this bit. And yes, I owned a 900 Div for a couple of years.
    Maroon, it was. Marooned, I wish it had been.
    The Older Gentleman, Nov 2, 2009
    #77
  18. TMack
    I'll leave it to you to arrange, since you have so much time on your
    hands.
    ogden, Nov 2, 2009
    #78
  19. TMack
    Domènec Guest
    Sesame Street^H^H^H^H^H Rue su Sésame:
    From "moto", "motard".
    From "bande desiné" (comic book), "bandedesinard".
    As per Domènec ever since this night ;)
    #79
  20. TMack
    Domènec Guest
    "The Older Gentleman" <> escribió en el
    mensaje de noticias
    Heh :)
    Concerning the Div's, I remember being not able to drag knee on a 600 in a
    trackday. Meantime the owner was having the time of his life on my
    Thunderace.
    #80
