Gift suggestions needed
Discussion in 'UK Motorcycles' started by TMack, Oct 31, 2009.
  1. TMack
    Is there another Fat Duck in London then?
    ogden, Nov 1, 2009
  2. TMack
    Eiron Guest
    Are you sure that was countersteering?
    Eiron, Nov 1, 2009
  3. TMack
    Clearly you know, as do I, that Ogden's confused about what
    countersteering means. Nothing unusual with that.
    Ace, Nov 1, 2009
  4. TMack
    Probably not. I was working til 7am, give me a break.
    ogden, Nov 1, 2009
  5. TMack
    Domènec Guest
    <fx: Farty Towel's Manuel>
    ¿Qué?
    </fx>
    Domènec, Nov 1, 2009
  6. TMack
    Domènec Guest
    "ogden" <> escribió en el mensaje de noticias
    Nah, but I'd need a hotel...
  7. TMack
    Nige Guest
    holy, not only
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Nov 1, 2009
  8. TMack
    It can take two?
    sweller, Nov 1, 2009
  9. TMack
    Heh. Yes.
    MT-03 will for sure.
    Pip Luscher, Nov 1, 2009
  10. TMack
    The Waterside Inn, just round the corner. That'd be lunch sorted for the
    next day too.
    ogden, Nov 1, 2009
  11. TMack
    Domènec Guest
    next day too.
    Ah, that's a nice start! :)
    Visited their website. I'm paging the local "who gives a **** about the
    price?" squad (double rooms a bit pricey, but meals rather standard for
    Relais & Chateaux)
  12. TMack
    Where is TMack based? There's the place where Wizard(?) organized a
    ukrm flying day a while back - that was Herts wasn't it?
    *ding*
    I was given a voucher for Lasham, and weather permitting, will be
    soaring like a bird on the 22nd.
    http://www.lasham.org.uk/learning/trial_flights.asp
    CT, Nov 2, 2009
  13. TMack
    I found a quad quite easy to adapt to. A jetski however, was a
    different kettle of cod.
    CT, Nov 2, 2009
  14. TMack
    I am referring to the sit-on one, and yes, I am admitting that it took
    some time for me to get used to it! Once I did get the hang of it, it
    was fine.
    I've never tried a kneel/stand type, and I don't think I'll bother!
    CT, Nov 2, 2009
  15. TMack
    The whole 'leaning over' thing's a bit different if you're not used to
    boats, I suppose, although you counter it by leaning inwards, just
    like on a bike. Or was it the nearly-but-not-quite direct steering?
    You should try steering a proper big ship; typically any steering
    input takes fifteen seconds or more before you actually start to turn,
    so most novices will end up steering in increasingly wild zig-zags the
    first time, as you try to counter each swing with more and more
    opposite input, all of it being far too late to achieve the desired
    effect.
    They're actually more like a bike, in that you have to lean it into
    the turn to avoid being flipped off. The main difficulty is that you
    have to start off while in the water, then pull yourself up onto the
    platform only once you've started moving. Going from kneeling to
    standing also needs a special technique. Haven't tried one for about
    ten years, so I've probably forgotten it all now as well.
    Ace, Nov 2, 2009
  16. TMack
    It was before I'd done much sailing, especially dinghy sailing, but
    yes, it was more the steering. Once I'd worked out that if I just
    gassed it and didn't worry that the steering wasn't particularly
    precise, and not going in an exact straight line didn't matter, I was
    OK.
    I found that the first few times I helmed a 38ft yacht. I hate to
    think what it's like on a proper ship.
    CT, Nov 2, 2009
  17. TMack
    petrolcan Guest
    Too easy.
    petrolcan, Nov 2, 2009
  18. TMack
    Yes, I am very aware that it might take a number of attempts to get
    aloft!
    I'm only about 45 minutes away, so a call in the morning to found out
    if it's happening and a quick trip down the M3 & along the A339.
    If all else fails, there's always lunch in the Royal Oak[1] :eek:)
    [1] I'll make P drive to make up for my disappointment :eek:)
    CT, Nov 2, 2009
  19. What happened to that camp old queen?
    vulgarandmischevious, Nov 2, 2009
  20. TMack
    Switters Guest
    Doesn't even have to be that big. I used to go out on a converted fishing
    boat for diving trips and would have the same problem when the skipper let
    me drive.
    Switters, Nov 2, 2009
