Getting angry about speed cameras
Discussion in 'UK Motorcycles' started by tallbloke, May 17, 2005.
  1. tallbloke
    That stuff is nasty.
    Muck, May 17, 2005
  2. In uk.rec.motorcycles, Muck amazed us all with this pearl of wisdom:
    I was thinking that if you were caught with "combustibles" near a speed
    camera and you used the "I just got them from the shops, I'm on the way
    home" argument then your position will be strengthened if the shops you
    came from actually sold the stuff.
    Whinging Courier, May 17, 2005
  3. tallbloke
    True, that'll be why these sorts of things have to be carefully
    executed.
    Muck, May 17, 2005
  4. tallbloke
    TimP Guest
    Aaargh! I was flashed in Limehouse tunnel this lunchtime, and from what
    I read it's a digital system so incendiaries will be useless. Bugger.
    Is there any chance I won't get fined?
    TimP, May 17, 2005
  5. tallbloke
    Only if you were going really, really fast & get locked up instead.
    Krusty, May 17, 2005
  6. tallbloke
    TimP emerged from their own little world to say
    I thought the digital jobs used infra red flashes so they could work both
    ways without dazzling oncomers. Are you an alien species with IR vision?
    wessie, May 17, 2005
  7. tallbloke
    TimP Guest
    vision?
    Hmm. I've always thought my parents were weird. And the grill at home
    is _very_ bright. Perhaps you're on to something.
    <licks eyeballs>
    TimP, May 17, 2005
  8. In uk.rec.motorcycles, TimP amazed us all with this pearl of wisdom:
    Heh, Nice!
  9. tallbloke
    The ones in CH flash with a very red light, presumably including
    enough IR component at a lower cost than an IR-only flash.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, May 17, 2005
  10. tallbloke
    Ace emerged from their own little world to say
    there's also the visual "deterrent" aspect - must be seen to be collecting
    taxes
  11. tallbloke
    Aye, and that's pretty much how they're viewed here. With no points
    system in place it's just a speeding tax, and is graduated by your
    speed. Last one I had was about 60kph in a 50 limit and the fine was
    40 francs, about 18 quid. Hardly worth bothering with, but there you
    go.
    _______
    Ace, May 17, 2005
  12. If so, not for very much longer.
    Grimly Curmudgeon, May 17, 2005
  13. tallbloke
    The brain will register it, apperently, you can **** about with peoples
    brains by flashing an infra red strobe at some frequency, so that they
    sort of loose concentration or something... so I heard once.
    Muck, May 17, 2005
  14. tallbloke
    Salad Dodger Guest
    Shawly an IR image would just be a big bright blob where the engine
    was?
    | ___ Salad Dodger
    |_\_____/_| ..75127../..18583.../..3196./.19406
    \|^|/ ANORAK#17 IbB#4
    '^' RBR Landmarks: 12 Pts: 220 Miles: 914
    Salad Dodger, May 18, 2005
  15. tallbloke
    Salad Dodger emerged from their own little world to say
    http://www.speedcamerasuk.com/Truvelo.htm
    To avoid the 'flash' which is given out by a rear facing Gatso camera the
    Truvelo system uses an infra red flash which produces no visible 'flash' to
    the approaching driver. These rely on 3 white-lines in the road, painted
    just before the camera, and are triggered by strips in the road, used to
    gain the vehicles speed.
    wessie, May 18, 2005
  16. <Adds to shopping list>
    Boots Blakeley, May 18, 2005
  17. tallbloke
    Ace, May 18, 2005
  18. tallbloke
    Heh...
    Muck, May 18, 2005
  19. tallbloke
    TimP Guest
    Sadly it wasn't a Truvelo but one of these chaps:
    http://www.redspeed-int.com/en/customers_case_studies_limehouse.htm
    Basically a Gatso but with a digital camera so it doesn't have to be
    reloaded.
    As I understand it there are three of these in each tunnel (east/west),
    plus a SPECS system monitoring average speed through the entire lot, so
    just cruising through at 35 could mean you lose your licence. Madness.
    TimP, May 18, 2005
  20. tallbloke
    gomez Guest
    And a bigger but less bright image where *you* are?
    gomez, May 18, 2005
