German engineering...
Discussion in 'Classic Motorbikes' started by Austin Shackles, Feb 20, 2004.
  1. being as it was a nice day, I thought I'd haul the bike out of the shed and
    see if it still runs...
    kicked the kickstart quite a bit, and also tried pushing it down the yard,
    to little effect (yard's dead flat) so I thought sod this.
    dug around in the shed and found the electric starter, fitted same, dug
    around some more and found the switch, went and looked up which wires to
    connect where, connected it all up. dead as a dodo.
    hmmm.
    looked more at the wiring diagram. aha. starter relay. found that and
    looked at it, after a bit noticed that the trigger wire was on the wrong
    terminal, which of course with the switch missing made no difference. put
    it on the right terminal and it worked. bike turning over, battery mostly
    flat.
    fetched spare tractor battery and jump leads. Now *thats* what I call
    turning over... after a few seconds, it fired up on the right pot, and after
    a bit more, the left one decided to play as well. Ran it for a bit, shut
    off, put all miscellaneous bits back on and now it'll (just) fire off its
    own battery.
    will give it some exercise this afternoon.
  2. Austin Shackles
    Steve Parry Guest
    In
    <snip tale of British bodgery ;o) >
    um er um yes ... so I guess your application for the BM owners club is
    still in the post then Austin?
    Steve Parry
    http://www.gwynfryn.co.uk
    K100RS SE
    F650
    Steve Parry, Feb 20, 2004
  3. Austin Shackles
    Triffid Guest
    You've got a H*rley as well?
    Triffid, Feb 20, 2004
  4. eh? whassat? wasn't any bodgery, to speak of. standard parts, all of 'em.
    never saw the need to fit 'em before.
    have you seen the beast? it's on the web somewhere...
    http://www.ddol-las.fsnet.co.uk/boxer should work, the thumbnails are crap
    but the pages were only knocked together in about half an hour.
    still no progressive springs, though...
  5. Austin Shackles
    Battleax Guest
    Is that a piece of galvanized sheet metal under the seat? Now THAT'S a
    bodge!
    Get that piece of roofing metal out of there and make a proper piece from
    aluminum.
    B
    Battleax, Feb 20, 2004
  6. roofing metal? I'll have you know that's a high quality off-cut from the
    panelling on a trailer. Can't quite remember why it's there, I'm sure there
    was a reason at the time. Makes a handy place to rest tools and stuff when
    working on it.
  7. Marvellous. Needs rear-sets, mind.
    Platypus - (unreal)
    VN800 Drifter, R80RT, Z200
    DIAABTCOD#2 GPOTHUF#19
    BOTAFOS#6 BOTAFOT#89 FTB#11
    BOB#1 SBS#35 ANORAK#18 TWA#15
    pseudoplatypus, Feb 21, 2004
  8. got 'em, what it really needs is the controls sorting to be able to ride on
    'em.
    not sure if they're on the pictures, I put the pillion pegs back on it so as
    to be able to use 'em as alternatives.
    ran OK down to the caff yesterday too. and it'll start on the button, once
    it's been run a bit to charge the battery :)
    Austin Shackles, Feb 21, 2004
