Gears on Overrun...
Discussion in 'UK Motorcycles' started by Robbo, Apr 1, 2005.
  1. Robbo
    Robbo Guest
    Occasionally when decelerating quite hard down the box on the Trophy it
    chucks a wobbly and loses third gear.
    I'm almost used to it happening now so look out for it and change back into
    gear as it happens.
    Problem is it's annoying when you *really* need that downshift.
    So, any suggestions as to probable cause?
    I reckon dodgy detents in the selectors.
    Robbo
    Trophy 1200 1998
    B.O.S.M 2003, 2004
    FURSWB#1 KotL..YTC449
    PM#7
    Robbo, Apr 1, 2005
  2. Robbo
    Or a bent fork or rounded dogs.
    Pip Luscher, Apr 1, 2005
  3. Yep.
    The Older Gentleman, Apr 1, 2005
  4. Robbo
    Robbo Guest
    Which?
    or all 3
    Robbo
    Trophy 1200 1998
    B.O.S.M 2003, 2004
    PM#7
    Robbo, Apr 2, 2005
  5. Robbo
    My money would be on forks or possibly dogs, though IME it's usually
    the other side (the drive side) that gets rounded.
    Also, the detent *ought* to affect both drive and overrun, errr, but
    so would a bent fork I guess.
    Could be a bevel gear is shifting a shaft axially slightly under
    reverse load, thus making a slightly iffy gear engagement worse on
    overrun. In that case, any of the options could still apply, plus the
    possibility of excessive shaft endfloat as a fourth option.
    The detent mechanism is at least easier to get at on some bikes.
    Sometimes it's behind the clutch, not in the gearbox itself, so you
    might not need to split the cases to find out. Same goes for endfloat
    on the shafts - they're all accessible one way or another.
    Pip Luscher, Apr 2, 2005
  6. Robbo
    Tim Guest
    Probably as one may induce the other. There's only one way to find out.
    Tim, Apr 2, 2005
  7. Robbo
    I'd try changing the make and or type of oil that goes in the bike to
    see if that helps an any way.
    Muck, Apr 2, 2005
  8. Robbo
    Bad form an' all: _helical_ gear. Twit.
  9. Robbo
    Dan L Guest
    It's fucked.
    Give you a tenner for it.
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R
    Spare Bike 1990 Suzuki TS50X
    Dan L, Apr 2, 2005
  10. First sign of gear changing without using the clutch enough/at all and
    matching the throttle/engine speed to the drive side of the box.
    Mick Whittingham, Apr 5, 2005
  11. Robbo
    You're talking about cars there, how exactly can you rev match on a dog
    box?
    Muck, Apr 5, 2005
  12. It's called slipping the clutch and matching the revs on the change. You
    have synchromesh on a car and don't worry so much or you have a non
    synchromesh box then you double declutch through the shift.
  13. Robbo
    I get you now, bliping on the down change. I used to double declutch on
    the lower gear down changes on my Landy, so I know what that is. :)
    Maybe Togs clutch is dragging a bit?
    Muck, Apr 5, 2005
  14. I read that as 'crutch' and thought:
    "TOO MUCH INFORMATION"
  15. Robbo
    =:-O
    Muck, Apr 5, 2005
  16. Robbo
    Muck says...
    I learned to drive in Series 1 and 2 Landies with no synchro on any
    gears. My dad used to laugh at me double declutching his Moggy Minor
    when I drove it round the village aged 13 or 14.
    Lozzo, Apr 5, 2005
  17. Robbo
    I had a gf that could only drive an auto car. She just got confused when
    I double declutched the Landy. "Looks complicated" she used to say.
    There again, she was only a web designer.
    Muck, Apr 5, 2005
