Gear shaft snapped
Discussion in 'UK Motorcycles' started by Wingedcat, Jan 13, 2009.
  1. Wingedcat
    Wingedcat Guest
    Girlfriend fell off her bike this morning (woman did a U-turn as she
    was filtering and she went straight over the bonnet). Luckily she is
    okay, her Yamaha YBR-125 is not looking too clever though.
    It looks like she will be claiming off the woman's insurance, but
    these things take time, and she only has 3rd party. So, I want to fix
    it in the meantime.
    Biggest problem is that the gear shaft has snapped off almost flush
    with the gearbox, leaving the (steel) gear lever intact, but leaving
    me with a slightly more difficult problem to solve. Am I right in
    thinking the gearbox has got to come to bits, and how tricky a job is
    it likely to be? Would a Haynes manual cover this procedure?
    I would tackle almost any job other than gearbox disassembly on this
    bike without too much hesistation, it's just that I have a vision of
    springs, cogs, bearings etc flying everywhere the second I take the
    cover off.
    Thanks in advance
    Luke
  2. Wingedcat
    TOG@Toil Guest
    Hmmmmm. On some bikes, quite a few actually, you can remove the gear
    shaft from the right-hand side of the engine, after you've removed the
    clutch, oil pump and other assorted gubbins. So you don't have to
    split the cases. Don't have to take the engine out of the frame, even.
    I've no idea if the YBR falls into that category, but a Yam dealer
    would know
    TOG@Toil, Jan 13, 2009
  3. Wingedcat
    I'm pretty sure you are correct. I don't know of a single Yamaha engine
    taht requires the cases to be split to replace the gear selector shaft.
    Sidecase, clutch complete and gear selector mech are all that need to
    come out usually
    Lozzo
    SV650S K5, ZX-7R P4, CBR600F-W, SR250 SpazzTrakka, SR250 Project
    SpazzCaffer
    I see a bright new future, where chickens can cross the road with no
    fear of having their motives questioned
    Lozzo, Jan 13, 2009
  4. Wingedcat
    bod43 Guest
    .... and yes, would expect it to be covered in Haynes.
    bod43, Jan 13, 2009
  5. Wingedcat
    Dave Emerson Guest
    AOL though you could find it /much/ more complicated if the shaft bent
    before it broke - as is likely.
    We had such a case down The Workshop where one of the guys had let his chain
    get so slack it had jumped the sprockets and wrapped around gear-change
    shaft.
    We had to cut it flush with the inner seal before it would pass thru and out
    the other side.
    YMMV
    Dave Emerson, Jan 13, 2009
  6. Wingedcat
    Derek Turner Guest
    Have I missed something or is this eligible for the FBOTY award? If so
    congrats. and commis.
    Derek Turner, Jan 13, 2009
  7. Wingedcat
    what name does she post under?
    wessie, Jan 13, 2009
  8. Wingedcat
    Eiron Guest
    You missed Molly's arcane rules which are discussed every January.
    Eiron, Jan 13, 2009
  9. What? I doubt it.
    Not only a non-regular, but the g/f of a non-regular.
    Grimly Curmudgeon, Jan 14, 2009
  10. Wingedcat
    This is Derek linuxmint Turner though, innit. A wild-eyed prophet
    living in a cave at the back of the High Street, he prefers to
    subscribe to the edgier theories and live life on the edge.
    Pip, Jan 14, 2009
  11. Wingedcat
    Wingedcat Guest
    Definitely not FBOTY. She's always accusing me of "spending too much
    time on those flipping newsgroups" so she can shove the award as far
    as I'm concerned.
    Thanks for all the tips.
    Luke
    Wingedcat, Jan 14, 2009
  12. Wingedcat
    Eddie Guest
    Well done; there are many of us here that have heard those exact words.
    But learn to snip sigs and extraneous text from your replies, or you'll
    be the one that's getting something shoved.
    Eddie, Jan 14, 2009
  13. Wingedcat
    Derek Turner Guest
    Hey, I only asked! :)
    Derek Turner, Jan 14, 2009
