Gear Change Difficulty
Discussion in 'Motorbike Technical Discussion' started by Alasdair Baxter, Aug 9, 2004.
  1. I ride a 1995 Honda CB Two-Fifty (not the Superdream) and I am having
    a great deal of difficulty changing gears once the engine has got hot.
    When I start off from cold, there is no problem till I have gone a
    couple of miles.
    Although I pull the clutch right in, I have to use quite a bit of
    force on the lever to enter the gear and if I want to select neutral,
    it's almost impossible. To get into neutral from first, I have to
    pull in the clutch and push the bike forward with my feet on the
    ground and then it slips in.
    I have tried adjusting the clutch lever but to no avail.
    I have even thought of having a hydraulic clutch mechanism fitted if
    this is possible although if possible, I suspect it will be extremely
    expensive.
    Any offers of help or advice please?
    Alasdair Baxter, Nottingham, UK.Tel +44 115 9705100; Fax +44 115 9423263
    "It's not what you say that matters but how you say it.
    It's not what you do that matters but how you do it"
  2. Alasdair Baxter
    Ed Rubin Guest
    Well it's almost definitely clutch drag. I would check out the clutch
    release mechanism inside the primary case. If you need to disassemble
    the clutch you will probably need a special spanner to undo the slotted
    nut that holds everything together. I'm basing this on my knowledge of
    the CM250 which uses the same engine.
    Ed
    Ed Rubin, Aug 11, 2004
