I've heard that it's a poor idea to use a carb cleaner that you add to your tank of gas when you fill up. But it seems to be the most simple solution to a little gunk in the carbs. Is it truly bad to put those gasoline additives through a bike, and if so, why, what does it do that is so undesirable. I need to clean my carbs but the bike is running, and i'd rather not completely disassemble the carbs unless it's completely necessary. If gasoline additives aren't going to work for me, are there any other simple solutions i should be trying, or should i just reside myself to a bit of work? Thanks in advance Mike
