Gasket Remover
Discussion in 'Motorbike Technical Discussion' started by Iowa883, Mar 20, 2005.
  1. Iowa883
    Iowa883 Guest
    Just wondering what you guys use for gasket remover ? Is there some aerosol
    that makes removing old gaskets easy ?
    Thanks,
    Iowa883
  2. I hope so! Over the years I've become a bit tired
    of using a 1/2 spackling knife or a single edge
    razor blade... There isn't an easy way to the best
    of my knowledge.
    Keith Schiffner, Mar 21, 2005
  3. Iowa883
    bob prohaska Guest
    There are spray-on gasket removers, which appear to
    be roughly the same as paint remover. They work, but
    watch the overspray!
    Paint remover applied with a brush is likely to do
    the same job at lower cost with less collateral damage.
    bob prohaska
    bob prohaska, Mar 21, 2005
  4. Methylene chloride will remove gaskets but I would want to spray it
    around, it would take the paint off of surfaces that I want to remain
    painted. So, buy a few "acid" brushes to apply it...
    krusty kritter, Mar 21, 2005
  5. Iowa883
    MadDogR75 Guest
    Try "Gunk` aerosol brake cleaner .... it dissolves most everything,
    but don't get it on painted surfaces or breath too much of the fumes.
    Spray it on outdoors and let it sit a while, then scrape.
    MadDog
    MadDogR75, Mar 21, 2005
  6. Iowa883
    Don Fearn Guest
    Easy-Off oven cleaner. Only DON'T get it on any painted surfaces!
    -Don
    Don Fearn, Mar 22, 2005
  7. Iowa883
    E. Goforth Guest
    Hello, Don Fearn !
    I believe EZOFF contains lye, which will attack Al, I wouldn't
    want to leave it on Al for very long.
    -Eric
    E. Goforth, Mar 22, 2005
  8. Bzzt! Do NOT spray Easy-Off oven cleaner on any aluminum surface!
    The sodium hydroxide (lye) will eat up aluminum. It would be OK on a
    set of old Chevy cast iron cylinder head but motorcycle parts aren't
    cast-iron...
    krusty kritter, Mar 22, 2005
  9. Iowa883
    Frank Guest
    I've used a plastic windshield scraper with good success. It ruined
    the scraper, but it was June so I didn't really care ;-)
    Frank, Mar 24, 2005
