garmin newly overhauled zumo 550
Discussion in 'UK Motorcycles' started by mark, Aug 20, 2010.
  1. mark
    mark Guest
    Does anyone know what 'newly overhauled' actually means?
    mark, Aug 20, 2010
  2. mark
    Amazon have them and it is advertised with a 12 month guarantee so it must
    be similar to factory reconditioned
    wessie, Aug 20, 2010
  3. mark
    petrolcan Guest
    Refurbished.
    petrolcan, Aug 20, 2010
  4. mark
    mark Guest
    I suspect this.....
    mark, Aug 20, 2010
  5. mark
    mark Guest
    Yes. But what exactly do they recondition when it's in the factory?
    I have an image of Garmin drones sweeping up discarded and broken 550's
    from all around and taking them off to be polished and repaired........
    mark, Aug 20, 2010
  6. mark
    mark Guest
    Restored?
    mark, Aug 20, 2010
  7. mark
    With Garmin they will have the same appearance as a new unit and tested
    to the same level as new ones. They are giving them the same guarantee
    is new, retail units.
    Most likely they will be units never sold to customers, either held in
    the factory after failing the test process or recalled from the
    distribution network once a fault became apparent. I used to run a unit
    for Xerox that did this sort of thing for their self-made printed
    circuit boards. You get a couple of failures in the field so recall the
    whole batch of maybe 10,000 units to be reworked. All because someone
    didn't clean a solder paste screen very well, giving you a few dry
    joints that escaped the test process.
  8. mark
    mark Guest
    Thank you all :)
    mark, Aug 21, 2010
