garden tractor starter snafu
Discussion in 'Motorbike Technical Discussion' started by michael.janket, Dec 6, 2008.
  1. My 1987 Honda HT3813 tractor won't start. I have a new battery and
    new solenoid. I turn the key, get a click. Sequentially, where do I
    start the diagnosis process? Do I have a broken wire that won't
    deliver enough juice to the solenoid? Do I jump from battery to
    terminal with another wire? Do I splice in another wire from the
    starter switch and attach that to the small in terminal in the
    solenoid that carries a smaller voltage from said switch?
    Must be a simple way to piece this together, suggestions very
    welcome. Gotta be simple. thanks all, Mike
  2. michael.janket
    . Guest
    If you get one click every time you turn to key to START, that
    probably indicates you have worn out brushes in the starter, which
    requires
    engine removal and flywheel removal before you can get to the starter.
    If the starter solenoid clicks rapidly several times, that indicates a
    weak battery.
    The best way to find out whether the solenoid contacts aren't making
    good connection is to jumper from one big terminal to the other. If
    the starter cranks, it's the solenoid.
    You can also jumper from the battery directly to the terminal on the
    starter, if it's accessible. If the starter cranks, the problem is
    somewhere in the cables, perhaps just a bad connection at the battery,
    solenoid, or starter.
    One problem which isn't obvious to most mechanics occurs when the
    engine block corrodes and the starter can't make a good ground to the
    engine.
    And, if there is a ground jumper from the engine to the chassis, make
    sure that's making good contact.
    ., Dec 6, 2008
  3. michael.janket
    Who Me? Guest
    Before you get too carried away with the other stuff, listen for a whine
    after the click, which would indicate a failed engagement mechanism OR a
    stripped gear on the starter. Also WATCH the flywheel. If it tries to
    move just a little bit and stops, that could be a sign of a seized engine.
    Who Me?, Dec 7, 2008
  4. You also could try tying a rope to the tractor, the other end to your
    car, and have someone pull the tractor along at a couple MPH and
    drop the clutch to push-start it and see if the engine at least fires.
    Ted
    Ted Mittelstaedt, Dec 7, 2008
  5. If the solenoid is clicking, you're getting juice to the solenoid. I'd
    check the connection from the solenoid to the starter motor itself next.
    Easy check is to run a length of starter cable from the battery to the
    starter motor itself. If it spins, the problem isn't the starter motor,
    but the wiring between it and the switch or, most likely, it and the
    solenoid.
    The Older Gentleman, Dec 7, 2008
  6. michael.janket
    Who Me? Guest
    On most recent lawnmowers, there is no "clutch".
    Will that work with a modern hydro-static transmission ?? I doubt it.
    Like modern automatic car transmissions void of a "rear pump" that won't
    push start, I'd think the same would be true of a lawn mower hydro
    drive......but I don't really know.
    Both of mine seem to have a distinct braking function when the pedal is
    neutral.
  7. michael.janket
    . Guest
    http://i107.photobucket.com/albums/m314/Restrorob/Honda/HondaHT3813Starter.jpg
    The solenoid is right there at the starter, it shouldn't be much of a
    problem to
    jumper from the solenoid to the starter.
    The starter has a bendix drive and what looks like a one-way sprag
    clutch on the reduction gear.
    ., Dec 7, 2008
