Garage archaeology - drills/drill stands
Discussion in 'UK Motorcycles' started by Pete Fisher, Jul 5, 2010.
  1. Pete Fisher
    Pete Fisher Guest
    After completing carting the demolished remains of the old timber
    greenhouse to the tip and clearing out the aluminium one[1] I have
    finally started on the garage.
    Slightly depressing happening on odds and ends for bikes that I haven't
    owned for twenty years and all those old tools that rarely get pressed
    in to service unless doing more than a bit of fettling.
    Buried at the back corner of the bench I found the old Wolfcraft drill
    stand and vice that I used when creating engine mounting plates and
    spacers for the 'Rotarini'. Amazingly, with a squirt of GT85 and a bit
    of reciprocation it still appears to function. I was just about to carry
    on cleaning it up when I wondered whether my seldom used corded drill
    was OK. Then I remembered it died a couple of years ago and because most
    jobs since then have required only a well charged cordless I hadn't
    bothered to replace it.
    It is from the era when drills had a collar *and* notches required to
    fit into a sort of 'Y' shaped bit on the ancient drill stand (along with
    a screw down retainer in to a circular recess on the back of the drill).
    The stand dates from the time when drills didn't have collars but only
    the notches for attaching to sanders and saw attachments.
    From a quick Google it seems that modern drills no longer have notches
    at all. Is this universally the case? If so I might as well throw the
    drill stand on the tip. Which is a shame, as I might need it
    occasionally in the course of the planned Morini 2C/375 rebuild. I
    missed the cheapo Aldi pillar drill a couple of years ago, but is there
    another recommended pikey item that would do the job, rather than having
    to buy a new drill[2] and a stand?
    [1] I must confess, that as a result, the shed housing GFR#1 and the
    Morini 2C/375 is now stuffed to the gills with boxes of things that
    might "come in useful".
    [2] Though I ought really to have a corded 'hammer' job for those very
    rare (for me) DIY occasions that demand one.
    | Pete Fisher at Home: |
  2. I bought a Makita 1501 hammer drill about 12 years ago. It has drilled more
    holes than I've had hot dinners and never missed a beat. I would buy another
    one in a heartbeat if it burst into flames tomorrow. Highly recommended.
    Fraser
    Fraser Johnston, Jul 6, 2010
  3. Pete Fisher
    Paul - xxx Guest
    Heh .. we still have a Black and Decker orange and white coloured drill
    that uses this system. Whilst it still works it's still useful .. even
    if the hammer function is now more a gentle pulsing .. ;)
    In fact we should still have the Jigsaw, circular saw and sander
    attachments for it in the same box, somewhere in the shed.
    Paul - xxx, Jul 6, 2010
  4. Pete Fisher
    I also have a B&D[1] drill and attachment set, bought as an engagement
    present back in around 1980, which still sees occasional use. Most
    recent was skimming a couple of doors with the circular saw a couple
    of weeks ago, after new carpets were fitted. It would probably have
    been easier if I weren't still using the original blades in it...
    [1] Fnaar.
    Ace, Jul 6, 2010
