FZ400 fork spring woes and advice needed (longish)
Discussion in 'UK Motorcycles' started by Lozzo, Sep 15, 2003.
  1. Lozzo
    I've been working on Elly's FZ400 these past few days,
    preparing the bike for its MOT and subsequent daily useage. One of the
    jobs that needed doing for the MOT was to ensure the forks didn't bottom
    out, as they had been previously. I've fitted new seals and the correct
    grade and quantity of oil, and had come to the conclusion that the
    springs were bordering on tired. When sitting still the bike exhibited an
    amazing amount of sag, with the fork stanchions sitting way down the
    sliders
    Now back in the old days, when I was a tightfisted urchin living on
    boiled string and fried dandelions, I used to pop a couple or three
    2pence pieces on top of each fork spring to give them a bit of assistance
    and upping the preload. So I went down this route with the FZ, only to
    find that three 2ps on each spring caused the front to be almost solid.
    So I decided to drop the amount down to two 2ps.
    I started with the left fork and whipped the top cap off and the bike sat
    pefectly upright and with the right fork leg fully extended still. All
    good for when I come to stick the top-cap back on I thought. I removed
    one coin and put the top-cap back on. Lovely.
    Turned my attention to the right fork leg and did the same, off came the
    top-cap, and the bottom yoke nearly clouts the mudguard as it drops. WTF?
    What I can't understand is how just 1.5mm of spacer can make that much
    difference to the way the front springs act. To put the top-caps on both
    forks took roughly the same amount of downward pressure and there was
    appx the same amount of spring sitting above the fork top when the cap
    was off each side. So I know that the damper units in each fork leg are
    seated at the bottom OK.
    I've since fitted 2 coins into each side and the front end seems to sit
    alot better with a minimum of sag and the forks don't bottom out any
    more. However, I'm still not at all sure I've done a proper job of it and
    can't ride it yet to be able to tell. That left fork not supporting the
    bike on it's own has thrown me. The right one coped very well doing the
    same job. Could I have just got the damper unit unseated on the right leg
    causing the preload to be way too hard the first time round, and if so,
    why did the top cap go on so easily that time? Anyone got any clues?
    Lozzo
    ZZR1100D, GPZ500S, CB250RS
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14.
    www.mjkleathers.com
    Lozzo, Sep 15, 2003
  2. Lozzo
    Sean Guest
    Lozzo wrote:
    Some of us still do use 2p pieces to up preload on bikes with non-adjustable
    suspension. Well, I do anyways even if it means drilling a hole in the
    middle of them to allow the damper adjusting rod through.
    As it should really.
    Assuming the resting state of the springs means they are both at the same
    'height' in the fork when they are fully extended, about the only thing I
    can think of is one spring has a much much lower compression rate.
    I changed the springs in the GTR yesterday with the bike on its mainstand,
    so the front wheel was on the ground all the time ( couldn't find my jack
    until I'd completed the job, as is usually the case ). Each leg was capable
    of supporting the weight of the front on its own. Mind, it probably only
    puts about 50-75lb onto the front wheel when on the mainstand.
    Personally, I would be cautious of riding it until I'd solved the mystery,
    just in case.
    Sean, Sep 15, 2003
  3. Lozzo
    Champ fascinated us all by saying...
    No shit Sherlock :)
    I'll take them out and strip them again tomorrow, paying extra attention
    to the variable damper units and the way they sit in the damper rod tops.
    I think the right hand one wasn't seated right after I fitted the 3 coins
    to the top of the spring, hence it was able to support the whole bike cos
    the preload was set at about 400% of maximum available. Quite how I
    managed to get the top cap on is beyond me though.
    Lozzo
    www.mjkleathers.com
    Lozzo, Sep 16, 2003
