Further to the debate about whether bikes are fired up on the production line ...
Discussion in 'UK Motorcycles' started by SD, Aug 11, 2006.
  1. SD
    SD Guest
    .... I've just read an article from Cycle World in 1994.
    apparently:
    A GL1500 takes 2.5 hours to build, about the same as a Civic.
    There are 34 processes, timed at 5 minutes each.
    Each bike has around 2000 parts, the same as an Accord.
    Job #1 is fitting the wiring loom to the frame, then engine, tank,
    cooling sytem, swing-arm.
    Then it's front end, air box, clutch and brake systems.
    Then bodywork. Back to front. Fairing last.
    Then it's ridden off the line under its own power.
    Then the stereo goes on, as does the windshield.
    | ___ Salad Dodger
    |_\_____/_| ..81750../..22169.../..31893.
    '^' RBR Clues: 23 Pts: 440 Miles:1738
    SD, Aug 11, 2006
  2. At 2am in the morning!
    Are you an insomniac?
    Mr Alun Davies, Aug 11, 2006
  3. SD
    BGN Guest
    I suppose it's better than 2am in the afternoon.
    BGN, Aug 11, 2006
  4. SD
    deadmail Guest
    I think you'll find plenty of the regular posters have problems with
    sleeping.
    deadmail, Aug 11, 2006
  5. SD
    MikeH Guest
    Regular readers dont.
    MikeH, Aug 11, 2006
  6. SD
    *Excellent*
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Aug 11, 2006
  7. SD
    SD Guest
    Six forty-four? Have you got a paper round, or something?
    | ___ Salad Dodger
    SD, Aug 11, 2006
  8. SD
    NAHAY?
    platypus, Aug 11, 2006
  9. SD
    antonye Guest
    I must have missed the original thread [1] but IME, the Italians only
    run the bikes at the end of the fitting process. The engines are built
    up first (one person [2] per unit) and once assembled they are
    spun up for compression testing. Any units which fail at this point
    are examined and fixed before testing again.
    The bike is then assembled fully before being run on a dyno at
    the end of the line to check for full power across the range. Any
    duff ones are sent to the Germans.
    [1] are you pulling legs again, SD?
    [2] actually, most are assembled by women due to their
    better ability to handle the small components - this is a
    long story tied in with the closure of the La Perla lacy
    underwear factory in town and the gubmint forcing Ducati
    to take on all the (women) workers. They found that their
    skills with the intricate lacework transferred perfectly to
    the engine assembly, and this remains today. [3]
    [3] this is probably more interesting than the rest of this post
    antonye, Aug 11, 2006
  10. SD
    zymurgy Guest
    Nope !
    P.
    zymurgy, Aug 11, 2006
  11. And all the line workers get an earful of "Boogie Nights".
    Grimly Curmudgeon, Aug 11, 2006
  12. One needs to get up early to read the drivel before anyone else...
  13. That's when I usually get the bus in the morning.
    Paul Corfield, Aug 11, 2006
  14. SD
    Dave Emerson Guest
    Having tried to remove <insert any specific component> from some bikes you
    get the distinct impression that the manufacturing process goes something
    like...
    1. Start with <insert specific component>
    2. Build the rest of the m/c around said component to make it as difficult
    as possible to remove.
    The item that comes to mind for me would be the battery from a Suzuki
    Intruder but I'm sure there are many more...
    Dave Emerson, Aug 11, 2006
  15. SD
    TBH, the bit about assembling engines being fiddly sounds suspect, to
    say the least.
    Switchgear I could understand.
    Hmm. I wonder what the Italian for "pingfuckit" is?
    Pip Luscher, Aug 11, 2006
  16. SD
    On the BMW xxxLT line it's "Charge of the Valkyries"
  17. SD
    SD Guest
    If you'd owned a GL1500, you'd know of about a dozen more already.
    Brake pipe from pedal to front left caliper is a goody, as is brake
    pipe to rear caliper.
    | ___ Salad Dodger
    SD, Aug 11, 2006
  18. Or "BMW Blues".
  19. SD
    antonye Guest
    'strue, honest.
    Ducati only assemble the engine at the factory, everything else
    is bought in, including switchgear.
    I reckon "pingfuckit" translates at "pingafuckitti".
  20. ShiteOldBoxer batteries.
    Yamaha XS650 electronic ignition modules.
    ShiteOldGuzzi air filters.
    Any Honda V4 - the centre valve adjusters on the rear cylinder bank.
    The Older Gentleman, Aug 11, 2006
