Further to my "attempted" break in thread...
Discussion in 'UK Motorcycles' started by dwb, Dec 5, 2003.
  1. dwb
    dwb Guest
    whats the opinion on obvious security, ie a big FO bar/device outside the
    garage door?
    In a way it's saying "there is something to steal" but on the other hand, it
    must dissaude the more casual person from attempting to bend open the door -
    something non-obvious security doesn't.
    I'm thinking of getting one of those "in front of the door" things and
    supplementing it with some other stuff in the garage.
    dwb, Dec 5, 2003
  2. dwb
    Steve Parry Guest
    In
    How about a sign such as
    "In the view of the owner of this property, Tony Martin was right
    to kill intruders to his property.
    If you choose to break into this property please bear the above
    statement in mind and also accept that the property owner is
    willing to go to prison to defend his property"
    should do it ... maybe :eek:)
    Steve Parry
    http://www.gwynfryn.co.uk
    http://wrexhamseals.tripod.com
    Steve Parry, Dec 5, 2003
  3. dwb
    Hmm let me think?
    Around here that should get half a dozen blokes in hoods with Armalites
    standing outside waving a jemmy and going *well?*
    Of course because we had blokes around with Armalites I was able to
    inadvertently leave my Beemer cage open and the garage door unlocked (Snap
    on tool cab/2 bikes inside) for a week this year (while on hols) without any
    problems.
    I was in Belfast on Wednesday and was sitting in a Cafe, it was reet busy so
    I ended up beside three coves, pudding basin hair/white Kappa shell suits/
    white trainers. Now two were obviously brothers and one of these was pushing
    the other in his wheelchair due to a knee/sledgehammer interface. I didn't
    like to inquire further :eek:) but I had the feeling it was saving other folks
    mucho hassle.
    Hog, Dec 5, 2003
  4. dwb
    Steve Parry Guest
    In
    addendum to signage .... " does not apply to NI due to increased
    numbers of suicidal psychopaths"
    Steve Parry
  5. dwb
    Steve Parry Guest
    In
    ..... do they catch criminals nowadays? ...
    Thought the resources only went to catch motoring offences?
    Steve Parry
  6. dwb
    Steve P Guest
    The advice we got from the police (after our multitude of burglaries)
    was that you can only deter the casual thief and something visible is
    often the best for this. If it looks like it will be a ball ache for
    them or make a lot of noise to get around they will hopefully go next
    door :) (nice neighbourly attitude).
    Depressingly he they also said that if the thieves are pros and are
    after your stuff then nothing will stop them.
    Steve P, Dec 5, 2003
  7. dwb
    dwb Guest
    Well this is the approach I am taking - obvious and not quite so obvious.
    Indeed - though if they are after the bike they're going to get a bit of a
    shock when they discover
    that despite it being a 2002 GSX-R it's done 14000 miles and isn't quite as
    pristine as they normally are at that age.
    Then again - they keep nicking Wizard's bike, so maybe I'm just fooling
    myself.
    dwb, Dec 5, 2003
  8. dwb
    HooDooWitch Guest
    Good point, well presented. ;)
    HooDooWitch, Dec 5, 2003
  9. dwb
    Steve P Guest
    No shocks with either of mine I suspect, both look a bit knackered :)
  10. dwb
    That's the way to go, Dan. FOAD lump of steel bottom centre of the
    door is a good deterrent - make sure the bottom of the door itself is
    reinforced so it cannot be folded up or cut easily to get around the
    lock, though.
    This I believe to be true.
    There is that - but too late once they've nicked it and do _just_
    enough damage to it in revenge and frustration so that it leads to a
    long hassle with the InsCo trying to decide whether to write it off or
    not ...
    Yeah, but they keep bringing the fucker back.
    I reckon you'd do well to get a couple of Rhodesian Ridgebacks and
    join the owner's club - place the membership stickers prominently,
    next to the "Bokker on Guard" notices and you should have no hassle.
    Pip, Dec 5, 2003
  11. dwb
    <snip, two sigs>
    HTF did that happen, then? Arse.
    Pip, Dec 5, 2003
  12. dwb
    dwb Guest
    Good point - didn't consider that - just slice around it and you've removed
    the effectiveness of the lock...
    I wonder what would be a good reinforcement that a) is easy to attach to the
    door, b) isn't stupidly heavy
    c) can't be cut through in an instant.
    That said, I will be locking on the inside in a different place but still I
    suppose if they want to cut through the door not a lot I can do about it :-/
    We had two in South Africa - absolutely lovely dogs and actually
    surprisingly calm and loving, but very loyal.
    Bit thick with it though, which lead to a few interesting moments.
    dwb, Dec 5, 2003
  13. dwb
    Well - a length of steel rod along the bottom of the door; a steel
    plate reinforcing the vital area; a solid piece of wood, even. You
    could bolt all of these through the door, then round the heads off so
    they cant't be undone or loosened from outside. Taping it in place
    forst and opening the door will soon tell you if the weight has
    unbalanced the door.
    Indeed - if they *want* in, they *will* get in. The thing to do is
    persuade them that it just isn't worth the bother - the thing is, they
    will want to be in as quickly and quietly as poss; then they can deal
    with local security on the bike and prepare to run it down the drive
    and into the van.
    Do as much as you can to deter them from trying to get in, in the
    first place - then, by use of a ground anchor and FOAD chain, loud
    bike alarm and baby monitor, coupled with IR cameras and floodlights
    controlled from inside the house, make 'em give up and/or catch their
    ugly mugs on camera.
    As has been suggested elsewhere, I reckon a good pair of hasps at the
    bottom corners of the door, with good solid padlocks are both
    reasonably subtle (and don't hurt as much when you kick 'em or stand
    on 'em when you're wheeling the bike about) yet effective when Team
    Scrote give them a hard look.
    If you are still worried, a couple of gate bolt jobbies with padlocks
    in the top corners of the door. These things are cheap and will leave
    plenty of headroom in the budget for a FOAD ground anchor and chain.
    Don't use Rawlbolts, use concrete adhesive - Screwfix carry this.
    I've come across a few - most interestingly when doing a house call
    with my big boss, who turned out to be shitscared of dogs - the bigger
    the dog, the more scared he was. I did the interview, he spent 30
    minutes with his back to the wall, sweating heavily, eyes popping -
    with a Ridgeback's nose in his nuts ;-)
    I like them.
    Pip, Dec 5, 2003
  14. dwb
    Verdigris Guest
    Serious thieves will know what you have in your garage, so the only issue
    is whether you can keep them out.
    Verdigris, Dec 6, 2003
  15. dwb
    Verdigris Guest
    A deck-chair, an armed psychotic and some speed.
  16. dwb
    Ah, that'll be the Free State down there vvvv
    Hog, Dec 6, 2003
  17. dwb
    For the more insane class of scrote, seeing that sign, they'd probably
    break in just to spite you [1].
    [1] Armed, "just how big are your bollocks..."
    sweller, Dec 6, 2003
