Further MoT madness ...
Discussion in 'UK Motorcycles' started by Pip, Apr 26, 2006.
  1. Pip
    Now the system is computerised, it wont/can't fail, right?
    Wrong.
    Elly's car ran out of test when she was away, so we knocked it in for
    test on her return - and it failed. Some fairly heavy-duty spannering
    ensued, the details of which I won't bore you with at this juncture,
    and a retest was booked. Apart from it isn't a retest these days,
    they have to carry out a full test, not just on the rectification
    works.
    There hangs the tale, dear reader. I attended the retest (following
    the 11th hour frantic bulb-replacing) at the appointed hour. They
    couldn't test it, could they? They haven't been able to test
    *anything* for 48 hours now ... as "the system is down".
    I asked them about the emergency manual option. They were fully
    conversant with the system ... but the system requires the tester to
    call a given number and announce the fault, the result of the test and
    jump through a few hoops before he is allowed to write the
    certificate.
    Siemens administer the system on behalf of VOSA. The "emergency"
    number connects to Siemens. Siemens have a recorded message, advising
    that the system is down and no test certs can be issued. And that is
    it.
    Game over, thanks for playing.
    Do not insert coin, the game is fucked.
    This is *not* limited to the one station I tried in Flitwick,
    apparently ...
    Pip, Apr 26, 2006
  2. Pip
    Greybeard Guest
    There you go then, fancy trusting something that needs reliability to the
    Krauts!
    Siemens I believe look after all the traffic lights as well.
    (Although, IIRC Siemens is now owned by Fujitsu!)
    Greybeard
    FLHRCI -01 UK ( 95 cu-in Stg 2. Big Boy!)
    Trumpet Trophy 1200 -96, (The Barge) for rainy days
    ukrm@foxtails[dot]co[dot]uk
    *** Posted via a free Usenet account from http://www.teranews.com ***
    Greybeard, Apr 26, 2006
  3. Pip
    Switters Guest
    That's truly shit.
    Switters, Apr 26, 2006
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, Pip
    Give the Beeb news bods a ring, they'll love this kind of shit.
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer
    Wicked Uncle Nigel, Apr 26, 2006
  5. Pip
    Monkey Guest
    I thought it had always been a case of 'as soon as it leaves the test
    centre, you have to have a full retest'? My understanding was that a test of
    the rectification works was only allowed if the garage that tested it had
    done the work.
    Monkey, Apr 26, 2006
  6. In uk.rec.motorcycles, Pip belched forth and ejected the following:
    Sounds like a perfect opportunity to get a bent MOT, not that it would
    be bent of course, just bought forward.
    Whinging Courier, Apr 26, 2006
  7. In uk.rec.motorcycles, Monkey belched forth and ejected the following:
    Last time I had a MOT done, if you wanted to take it away and do the
    work yourself you had to bring it back the same day or else you'd get
    charged the full fee and have a full test.
    This was only a couple of months ago.
  8. Pip
    Tim Guest
    IIRC that means there are ex-ICL people in there, enough said.
    Tim, Apr 26, 2006
  9. Pip
    Andy Hewitt Guest
    [Snipped Text]
    It's a nationwide problem, but that story by the dealer is bollocks.
    Their recorded message gives the testing stations authority to break the
    seal on their Emergency Testing Pack - which is a pad of hand-written
    certificates you can issue in lieu of the real thing.
    Andy Hewitt, Apr 26, 2006
  10. Pip
    YTC#1 Guest
    And as rule it depended on the type of item it failed on. ie a bulb was
    usually ok to take away and replace.
    YTC#1, Apr 26, 2006
  11. Pip
    SP Guest
    Go on then, who did the deed?
    http://news.bbc.co.uk/1/hi/uk/4948224.stm
    Lesley
    CBR600FW
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Apr 26, 2006
  12. Pip
    Daz Guest
    On Wed, 26 Apr 2006 16:47:40 +0100, Pip
    It won't be as they're all linked.
    This has been going on for 12 months in HGV testing but they can still
    do it manually(ish).
    Daz, Apr 26, 2006
  13. In uk.rec.motorcycles, YTC#1 belched forth and ejected the following:
    Mine (Mondeo) failed on rear suspension bushes and a CV boot had come
    loose.
  14. Pip
    Ali Hopkins Guest
    Correct. When I worked for that ghastly mob, we often bid against FJ for
    projects. The Fujitsu Siemens thing is a JV, separately owned. Fujitsu
    Services is the rump of ICL. The mob who run things like the MOT is SBS.
    Who run the Passport Agency.
    Ali
    Ali Hopkins, Apr 26, 2006
  15. Pip
    Greybeard Guest
    That explains it then.
    Wouldn't happen to run CSA or the Tax credit systems as well by chance Hmm?
    Greybeard
  16. Pip
    Ali Hopkins Guest
    Tax credit *used* to be EDS. I can't recall off hand who won that off them.
    CSA might be Capita, I think they run their call handling. Or is that CRB.
    Ali
  17. Pip
    Steve Parry Guest
    I thought the CSA was EDS?
    Steve Parry, Apr 26, 2006
  18. A sad comment on these technophilic times.
    Break Glass to Access Paper and Pencil.
    GS850x2 XS650 SE6a
    Every post contains Nutri-Ceramide-R and Pre-Biotics
    for your reading pleasure.
    Folding@Home Team UKRM
    Grimly Curmudgeon, Apr 26, 2006
  19. Pip
    Andy Hewitt Guest
    LOL, now that you put it that way.... :)))
  20. Pip
    TOG Guest
    It's the Beeb reading ukrm, innit? It'll be in MCN next week, too,
    linked to a story about superchargers.
    TOG, Apr 27, 2006
