Fuel Tank Repair?
Discussion in 'Motorcycle Technical Discussion' started by Zowie, Mar 8, 2005.
  1. Zowie
    Charlie Gary Guest
    The JB weld should work just fine if you properly clean the surface. Sand
    it down to bare metal, no paint at all for at least 3/4 inch from any edge
    of the repair. One inch is better. Clean it really clean with acetone. If
    you use white paper towels to rub the acetone into the part, it's very easy
    to see when the part is clean, because the paper towel won't show any dirt.
    Then you make sure you mix the pucky THOROUGHLY. Don't think the hardener
    will creep through later, because it don't. Mix it with one stick for at
    least 90 seconds, 120 is better. Do use a clock to time yourself. Apply it
    with a different stick to make sure you only have THOROUGHLY mixed pucky in
    your repair. Smear a thin layer into the surface like your life depends on
    it, and then pile it on smoothly, trying to ensure there aren't any air
    bubbles. If you need it, you can probably lay a small piece of tissue paper
    over the hole to hold up the goo once the thin layer is smeared on.
    Cigarette rolling papers work well here. Once it's on like you like it, you
    can speed things up a little with a hair dryer. Don't get it too hot or it
    will blister, but you can get it to 100 F trouble free. After it's hard you
    can sand it smooth with a hard block and some sand paper. Fill the low
    spots, sand it again, clean it, prime it with a rattle can from the auto
    parts store, and your tank is ready for paint. Did I mention the pucky
    needs to be mixed very well? That's important to a successful repair. Have
    fun.
    Charlie Gary, Mar 12, 2005
  2. Zowie
    LJ Guest
    When I did the tank off my honda. I turned it upside down, wiped it off,
    mixed the JB Weld a bit with a splinter of firewood I picked up off the
    floor and dabbed a little on with my finger. I let it sit overnight and
    reinstalled the tank. The repair was on the underside in an inconspicuous
    place, so I didn't worry about sanding/painting. It held for three years
    and I sold the bike. While I'm sure Charlie's method is superior, the stuff
    is pretty foolproof.
    LJ, Mar 12, 2005
  3. Zowie
    LOTP Guest
    To: "Zowie" <>
    Subject: Re: Fuel Tank Repair?
    Date: Saturday, March 19, 2005 12:33 PM
    FWIW:
    About 15 yrs ago I developed a pinhole leak in the bottom of my gas tank on
    the way to work (35 miles from home). I got home using soap (bar) rubbed
    into the leak...an old trick but not really safe or recommended. Once home
    I demounted the tank, cleaned the area, slightly enlarged the hole, and used
    Permatex two-part epoxy putty putty forced into the hole (in order to
    mushroom on the inside). I later sealed the inside of the tank with Kreem
    after proper cleaning and preparation. The tank is now on my son's bike and
    still holding strong.
    LOTP
    2 Triumph Trophys
    2 Suzukis
    1 Kawasaki
    1 Harley Sportster
    ----- Original Message -----
    Newsgroups: rec.motorcycles.tech
    Sent: Tuesday, March 08, 2005 2:59 PM
    Subject: Fuel Tank Repair?
    LOTP, Mar 19, 2005
  4. Zowie
    LJ Guest
    You could patch it, but I'd look to something like eBay where you have a
    sizeable hole. Right now there is a "new" tank , Item number:
    4535588682,going for around $100 (canadian?) and another tanke going for one
    cent, but it still has 6 days to go.
    LJ, Mar 19, 2005
  5. Zowie
    mcallan Guest
    I had a tank off of my seca that had simliar problem. Took it to local
    guy, he drained, flushed it, stuck nozzle of shop vac in filler to
    suck out fumes and welded it up no problems at all, hit it with some
    factory tuoch up paint, and your riding again.
    mcallan, Apr 24, 2005
