Fuel tank removal
Discussion in 'UK Motorcycles' started by David Thomas, Dec 2, 2003.
  1. David Thomas
    David Thomas Guest
    I need to remove the fuel tank to get to the air filter on my Bandit 600,
    have read the Haynes manual thoroughly an it says the following:
    Keep filler cap closed
    Switch tap to "on" position
    Remove fixings and lift rear of tank
    Disconnect fuel and vacuum hoses
    Ahhhh, won't the fuel just piss out in the "on" position or is the tap shut
    off because of lack of vacuum (via vacuum hose), and does the fuel only flow
    when in the "pri" position ?
    I know I can always drain the fuel off first but didn't want to do a
    complete drain down every time I want to remove the tank if it isn't
    necessary if you know what I mean.
    Doesn't mention anywhere in Haynes that the fuel won't piss out, but nor
    does it mention drain the bugger down or are they assuming that no idiot
    would take a tank off with fuel in it? apart from me of course :)))
    In the old days I used to just switch it to "off" which I ain't got now and
    whip the tank off.
    TIA, D
  2. In uk.rec.motorcycles, David Thomas said:
    I never took the tank off my bandit but shurly the best way to find out
    if the feul pisses out is to take it off and see if the fuel pisses out?
    If it does, turn the tap round. If it /still/ pisses out, kink the hose
    and hold it in place with some tape or a clip or something :)
    Whinging Courier, Dec 2, 2003
  3. David Thomas
    Salad Dodger Guest
    Exactly that, unless your vacuum diaphragm is buggered. If you want a
    fuel flood, you can always suck on the hose. As it were.
    Salad Dodger, Dec 2, 2003
  4. David Thomas
    David Thomas Guest
    Ah right, nice one ta
    D
  5. David Thomas
    Gyp Guest
    No, yes, yes
    Just get on with it, ffs
    Gyp, Dec 2, 2003
  6. David Thomas
    David Thomas Guest
    Tis done, all finished, now drinking beer.
    D
  7. David Thomas
    Kayman Guest
    Fear of being flamed aside [1]
    "Angle Grinder!"
    [1] Pun intended
    Kayman, Dec 3, 2003
