Fuel tank leaking: ideas?
Discussion in 'UK Motorcycles' started by Galet, Oct 24, 2008.
  1. Galet
    Eddie Guest
    That's only for trade membership; I think their FAQ's a bit misleading.
    It's a little like Makro, in that you need to be employed, but
    /slightly/ more restrictive in that only certain professions or
    employees of particular establishments qualify.
    We've got a joint membership by virtue of Mrs Eddie's profession, but
    could also have qualified because my employer is a preferred company.
    Eddie, Oct 27, 2008
  2. Galet
    Galet Guest
    Galet, Oct 27, 2008
  3. Galet
    fragmented Guest
    Milton Keynes Costo lets private people join.
    They have different opening hours for normal plebs Vs. company people
    for some reason, its not as if they have such superb bargains you have
    people queueing up outside waiting to mob the latest offers.
    fragmented, Oct 27, 2008
  4. Galet
    Galet Guest
    Bingo. Checked with the magic mirror, I'm not 100% sure but it looks like
    there is a small crack in this pipe. The pipe is made of two halves and
    in one point, more or less half way, there is a vertical crack, small but
    probably large enough to let the liquid pass between these two halves
    (stupid design IMHO).
    Now the big question: how do I seal this? It's not so easy to reach, I can
    reach the point with some tool but not directly with my hands. Or should
    I keep the tank always no more than half full?
    Thank you again guys...
    F
    Galet, Oct 27, 2008
  5. Is the filler cap one of those things with a flush surround, held in by
    half a dozen bolts or screws? If so, once you remove the entire filler
    cap assembly there'll be room to get a hand inside.
    The Older Gentleman, Oct 27, 2008
  6. Galet
    Plug the drain hole at the bottom of the tank, & get a small enduro
    style tankbag & leave it on all the time - sorted!
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Oct 27, 2008
  7. Galet
    Dave Emerson Guest
    Can you find a length of thin-walled plastic tube to line it with?
    Not sure of the diameter but I was thinking of the tubes that come with
    those cans of structural foam.
    Dave Emerson, Oct 27, 2008
  8. Galet
    Galet Guest
    I've removed the filler cap but still to narrow for a hand. I think I'll
    try with a kit and, in the worst case, I'll plug the bottom of this pipe.
    Thanks!
    F
    Galet, Oct 28, 2008
  9. Galet
    You do realise if you plug the pipe without stopping rain hitting the
    filler cap area, you'll end up with a tank full of water, yes? I had to
    drain the tank & carbs on a Raptor last week for precisely this reason
    (drain pipe got blocked with crud).
    Krusty
    Krusty, Oct 28, 2008
  10. Galet
    Have you not been getting them?
    You want to have a word with the security boys in your post room - a
    bit too zealous, I suspect.
    Champ, Oct 28, 2008
  11. Galet
    Galet Guest
    Yes, that's why I leave it as the last solution. I should probably seal
    the top of that pipe, too.
    F
    Galet, Oct 28, 2008
  12. Galet
    crn Guest
    Just buy a replacement tank. You will end up doing this anyway after
    faffing around for another week so do it now.
    crn, Oct 28, 2008
  13. Galet
    Galet Guest
    This is definitely the best solution. Do you have an idea of where I can
    find a tank for a GS500 2001 yellow, around London?
    Thanks,
    F
    Galet, Oct 28, 2008
  14. Set up an Ebay search.
    The Older Gentleman, Oct 28, 2008
  15. Galet
    crn Guest
    Your local Suzuki dealer.
    Or Google for bike breakers and take a chance on getting another bad one.
    crn, Oct 28, 2008
  16. Galet
    Galet Guest
    Sorry one more question... how do you set up a daily digest on ebay?
    I must be blind I cannot find the way!
    Thanks,
    F
    Galet, Oct 28, 2008
  17. Navigate to the section you're interested in. In this case, Cars, Parts
    & Vehicles --> Motorcycle Parts & Accessories.
    Click the Advanced Search button.
    Enter what you want in the search box. 'GS500 tank' should do it. Check
    the 'include title and description' box.
    To the right of where it says (at the time of writing this) '68 results
    found for GS500 tank' it says [save this search].
    Click that. Up pops the, er, pop-up, click Save, job done.
    It's worth setting up two or three searches. For example, you get people
    breaking bikes and just advertising a number plate bolt for a penny. So
    do a second one for 'GS500 breaking'.
    Also do one for GS 500 tank, because sometimes people don't get the
    model designation correct, and split it like this.
    It may pay you, if you get a really good tank at a silly low price, to
    buy one that's the wrong colour and have it painted.
  18. Packages of Wensleydale get taken straight out and into the 'controlled
    explosion' area.
    Grimly Curmudgeon, Oct 29, 2008
