Fuel starvation problem, Honda GL650
Discussion in 'Motorcycle Technical Discussion' started by Ken Long, May 11, 2006.
  1. Ken Long
    Ken Long Guest
    ('83 GL650)
    My petcock was leaking a bit whenever I would flip the lever to
    another position. The leak wasn't a lot but it was enough that I was
    afraid of running on reserve for any length of time and dripping raw
    fuel onto the engine. I purchased a rebuild kit for the petcock and
    took it apart to have a look see. After fixing the leak and putting
    it all back together, the bike was acting like it was fuel starved
    at 70 mph and up although it was fine at slower speeds.
    I wonder if someone who has taken these apart a few times can have a
    look-see at my pics and tell me if I've reassembled it correctly?
    http://home.comcast.net/~kenglong/honda_petcock/honda_petcock.htm
    Tia,
    Ken in Albuquerque
  2. Ken Long
    John Johnson Guest
    A fast way to check whether or not the petcock is allowing sufficient
    fuel flow is to put the end of the fuel hose into a container and move
    the level to the prime position. If there's a strong flow, you're in
    good shape so far. If not, there's a problem.
    Next, put the petcock into the On position and apply vacuum to the
    vacuum hose. The fuel flow should be the same as on the Prime position
    with vacuum applied, and nothing otherwise.
    Your pictures look fine, though that large plastic piece may go in the
    other way. It's either symmetrical and the spring is pushing it out, or
    it's not symmetrical and the vacuum cannot pull it far enough out of the
    way. I can't tell from here. HTH
    Later,
    John
    John Johnson, May 11, 2006
  3. Ken Long
    Ken Long Guest
    Good idea but this tap doesn't have a prime position. Just On, Off and
    Reserve.
    I've been needing a reason to buy a vacuum pump. I'll try this if the
    problem is still there. (I put everything back together this evening
    after reversing that diaphragm and blowing out the screen.)
    The picture shows a bevel that might indicate it's resting position
    should be toward the spring. I think, since I reassembled it as shown in
    the pic, it should require less vacuum to open the fuel path. (I'm
    hoping anyway.)
    It could also be that I was simply sloppy when I put it back together
    the first time. I was much more careful this time.
    Thanks,
    Ken
  4. R. Pierce Butler, May 11, 2006
  5. Ken Long
    John Johnson Guest
    You certainly don't need a fancy pump. If you're leery about applying
    vacuum by mouth, a 100cc syringe should be able to apply enough vacuum
    to do the job.
    Yeah, as R. Pierce Butler pointed out, the alignment of the components
    is pretty important in this application. You'll find out quickly whether
    or not you got it right. Good luck.
    Later,
    John
  6. Ken Long
    Ken Long Guest
    That o-ring was missing when I first took it off the tank. I
    reassembled it with an o-ring but there was no groove in the strainer
    tube.
    The bike still had the problem this morning after putting it back
    together with the diaphragm reversed. I think I might remove the
    o-ring completely and try it again...just to see what happens.
    Ken
    (Reply address works as is.)
  7. Is there any differnce in symptoms if in the normal or reserve positions?
    R. Pierce Butler, May 12, 2006
  8. Ken Long
    Ken Long Guest
    No difference. I rode it to and from work in the reserve position and
    it still did it.
    I need to verify one way or the other if the fuel tap is really the
    problem. I think I can remove the seal from the plunger and test ride
    it to check if the problem is still there. The tap should revert to a
    non-vacuum type where ON is always on even if the engine is not
    running. That should tell me if the problem is the vacuum-operated
    valve in the tap or if, just by coincidence, I've got something else
    going on.
    Ken
    Ken Long, May 12, 2006
  9. Try the old seal again and see if it still does it?
    Holes may be two small in the new one?
    ROBERT MILLER, May 12, 2006
  10. Ken Long
    Ken Long Guest
    Well.
    Circumstances have conspired against me and the problem was actually a
    very dirty air filter.
    While at work today, I was thinking that I should get a new air filter
    because the one in there was pretty dirty. Well, I took out the filter
    after work for the ride home and wow, all the old power was back again!
    It ran a bit lean with no filter at all but it was enough to tell me
    that the air filter was my problem.
    Ken
    Ken Long, May 13, 2006
