Fuel protests
Discussion in 'UK Motorcycles' started by Jeremy, Sep 12, 2005.
  1. Jeremy
    YTC#1 Guest
    Car computer shows as >>>miles to go :p
    Er, 'cos they are on a major road
    and 'cos gthey are on a major road
    I really hate to point this out, but you know that big thing between the
    head stock and your balls (on most bikes)? Well thats filled with petrol.
    And in an accident will often split. Then the metal bits spark. Personally
    I was happier with the petrol container on the pillion seat.
    You do read sigs don't you ?
    These are not bikes I have owned, but actually own and ride.
    Ok, so the GSX250 needs a good kicking and has not been ridden for 5 years.
    YTC#1, Sep 12, 2005
    #61
  2. Jeremy
    YTC#1 Guest
    Tell me about it.
    They want 450ukp for a new one !
    I mean , for a bike with 74.5k on it !
    Got one for 50ukp, awaiting repaint.
    YTC#1, Sep 12, 2005
    #62
  3. Jeremy
    Zanziba Guest
    You removed your petrol tank? Amazing.
    Why'dya own so many (especially the smaller cc's).
    I know I own cages for commuting but so do you, so why so many old bikes?
    Don't you have a favorite that you are happy riding? Don't the small ones
    feel underpowered after the larger ones?
    That's two of us then... We've both got out pics online.
    Zanziba, Sep 12, 2005
    #63
  4. Jeremy
    Zanziba Guest
    #64
  5. Jeremy
    YTC#1 Guest
    YTC#1, Sep 12, 2005
    #65
  6. Jeremy
    YTC#1 Guest
    You are taking the piss right ? I am refering to the "container" mentioned
    previously.
    because I fucking can !
    bikes?
    Cage for the times it is needed. Bikes for commuting whenever possible. Be
    it Manchest/London/Newcastle or Edinburgh. Too often I can't use the
    bike(s) due to the amount of kit I have to carry.
    I am (I suppose ) a biker.....
    The XJR is fun, it does silly things but is expensive to run, so I usually
    use the XJ900F for commuting. I like the shaft.
    The GSX750 is reallymy wifes, but is also heavilly used
    The GS550 is fun fun fun , and its a SOB and I don;t care (except it has a
    a leaky base gasket). The GSX250 is a rattly ****.
    They are all paid for, why should I get rid of any ?
    So , thats 2 cages, 5 bikes. I do more miles on bikes than cages, and the
    cage does arounf 15k a year.
    Yes, but you seem to be acting like one tonight.
    YTC#1, Sep 12, 2005
    #66
  7. Jeremy
    Zanziba Guest
    2 cages (one me, one wife) plus bike but bike is a sunday toy.
    Agreed, beer I guess, plus boredom. Finished marking BTW.
    #67
  8. Misleading bollocks. The program that first published that should be
    shot.
    Grimly Curmudgeon, Sep 12, 2005
    #68
  9. Jeremy
    Salad Dodger Guest
    I couldn't *afford* to go any faster.
    Yes, that's probably it.
    | ___ Salad Dodger
    _/_____\_ GL1500SE-V/CBR1100XX-X/CBX1000Z
    |_\_____/_| ..78875.../...19634.../..30836.
    (>|_|_|<) TPPFATUICG#7 DIAABTCOD#9 YTC#4
    |__|_|__| BOTAFOT #70 BOTAFOF #09 two#11
    \|^|/ ANORAK#17 IbB#4 PM#5 WG*
    '^' RBR Clues: 29 Pts: 485 Miles: 1967
    Salad Dodger, Sep 12, 2005
    #69
  10. Jeremy
    Fr Jack Guest
    Care to explain why, for the benefit of the uninitiated?
    Cheers!
    Fr Jack
    90 CB450DX (The Moped)
    FRJACKUKRM AT GMAIL DOT COM
    skype: fr.jack (without the dot)
    We'll open up your eyes,
    just to check that you're asleep, again
    Fr Jack, Sep 12, 2005
    #70
  11. It's that one teaspoon of white spirit isn't nearly enough of a
    diluent/additive to make any difference. That way lies fuel pump
    breakage (very expensive).
    Here's what works for me...
    New (SVO) used (WVO) at 60 to 70%, 30 to 40% white diesel, and about 5%
    unleaded. A dash of ATF to keep injectors clean every tankful helps.
    I have a heated fuel filter too - that's important.
    If you want to run purely on SVO/WVO, you _must_ use a heated fuel
    system - that's heated tank, heated pipe all the way from the tank,
    heated filter, and heated pipe to the pump. Generally this type of sytem
    is used as a two-tank one; you start up on ordinary diesel then switch
    over to SVO when the system is up to temp and the SVO viscosity is ok.
    Usually takes about 5 - 10 minutes on most vehicles.
    Grimly Curmudgeon, Sep 13, 2005
    #71
  12. was
    Christ. You're in training to be Bruce's acolyte and carry his awards,
    aren't you?
    The Older Gentleman, Sep 13, 2005
    #72
  13. Because it's fun!
    #73
  14. Jeremy
    Cripes, they'll be formidable.
    sweller, Sep 13, 2005
    #74
  15. £22 in the Trophy recently.
    Wrong - LRP is harmless to cats.
    [/QUOTE]
    Where did I say LRP hurt cats?
    That is my point exactly. Vehicles that require unleaded have the
    reduced size filler. LRP nozzels will not fit.
    ColonelTupperware,
    spouting bollocks on Usenet since 1997
    Usenet FAQ at
    http://www.its.caltech.edu/its/services/internetapps/news/news2.shtml
    UPCE FAQ at http://upce.org.uk/ UKRM FAQ at http://www.ukrm.net/faq/
    Colonel Tupperware, Sep 13, 2005
    #75
  16. Colonel Tupperware, Sep 13, 2005
    #76
  17. Colonel Tupperware, Sep 13, 2005
    #77
  18. Jeremy
    Ben Guest
    My trick in the queues today was to fill up with Super. Expensive,
    but no bugger wants it.
    Ben, Sep 13, 2005
    #78
  19. Jeremy
    YTC#1 Guest
    Only to fit more in, the GSX250 is at a mates as I have run out of space
    And thats the difference, bikes are more than toys. They make me smile,
    even in the wet. Even after serious offs (I have crashed in the dry and
    still go out on clear dry days).
    YTC#1, Sep 13, 2005
    #79
  20. Jeremy
    YTC#1 Guest
    Pity Dec 2001 Classic Bike is no longer on line :)
    YTC#1, Sep 13, 2005
    #80
