fuel injection vs carbs
Discussion in 'UK Motorcycles' started by Tim, May 10, 2011.
  1. Tim
    And then there's that popular engine for modified track cars - the 2-
    litre Vauxhall DOHC "red top" unit. The cheapest way to release an
    extra 20bhp from it, even in tuned/chipped/remapped form is to throw
    away the brain and the EFI and wedge a set of big old-fashioned
    carburettors on it.
    Pip, May 11, 2011
  2. Tim
    DozynSleepy Guest
    My first bike was an R80RT. Although compared to a modern Japanese bike
    it does seem very heavy and agricultural. Saying that, I'd have one again.
    Ask yourself if you want to ride a bike or sit in the garage working on it ?
    DozynSleepy, May 11, 2011
  3. Tim
    Tim Guest
    Definitely the former which is why I'm somewhat going off the idea of a
    bullet after doing a bit of research.
    Tim
    Tim, May 11, 2011
  4. Tim
    Cab Guest
    DozynSleepy wibbled forthrightly:
    I had one of those too. Excellent work horse for dispatching it was. I
    had the Plod version. Drained the battery like a cnut though.
    Cab, May 11, 2011
  5. Tim
    That's all very well, but you're still left with a fucking ugly,
    overweight, slow foul handling lump of a bike that is shit to ride.
    Given the choice I'd take the temperamental but fun bike over the
    boring blancmange on wheels any day.
    Lozzo
    they churn out)
    Lozzo, May 11, 2011
  6. Tim
    SteveH Guest
    I like my R100RT.
    But I did curse it last summer when most of the usual airhead things
    went wrong with it.
    Must drag it out of the garage and MOT it soon.
    SteveH, May 11, 2011
  7. Tim
    Hog. Guest
    An R100? Certainly not heavy. A Mono handles and stops very nicely. 70 BHP
    is nippy enough for an old 'un.
    Looks are in the eye of the beholder.
    Hog., May 11, 2011
  8. Tim
    Well, as older/cheaper ones use a common injector for all four
    cylinders, then no; differences in the path through the manifold to
    each cylinder will see to that, as will difference in the exhaust
    manifold path.
    It's probably more of a problem these days with tighter emissions
    regs.
    Pip Luscher, May 11, 2011
  9. Tim
    Or, in the case of my Quota, by plugging in a special connector
    (that's conveniently tied to the loom as standard) and counting the
    code flashes on the indicator LED.
    I've had two problems: a corroded wire on the phase sensor (flashy LED
    told me where to look) and a knackered head temperature sensor (flashy
    LED didn't help, but I eventually diagnosed it myself, even though the
    sensor was reading the correct value on a meter).
    Laptops? We don't need no steenking laptops.
    Idle mixture is adjusted with a screw on the ECU box.
  10. Especially with a set of DCOE 45s or similar on it, I would think the
    fuel consumption would be horrible.
    I still love SUs for sheer simplicity and function, but FI has a lot
    going for it. My main objection to FI on SOCs and SOBs is the spares
    situation when the more specialised bits go breaky.
    Grimly Curmudgeon, May 12, 2011
  11. Never = rarely. And with what you save in fuel it more than pays for
    itself.
    Fraser
    Fraser Johnston, May 12, 2011
  12. If you are happy with bugger all power and shit fuel economy.
    Fraser
  13. Tim
    tim Guest
    Cab's use of English is unlcear at this point, is he saying "fewer
    times" or "less often"? ;-)
    tim, May 12, 2011
  14. Old airheads are/were light and torquey, so the lack of absolute bhp
    never bothered me.
    The fuel economy did. The later they got, the more fuel they drank. My
    old heavy-flywheel R100RS was excellent: high-40s most of the time. I
    remember the light-flywheel R65LS did 45mpg whether I was caning it or
    nursing it along. My late Monolever R80 struggled to better 40mpg.
    I think all the anti-emissions stuff just choked them into inefficiency.
    The Older Gentleman, May 12, 2011
  15. Tim
    Peter Hill Guest
    The key to reliability is electronic FI doesn't get tampered with by
    monkeys when the vehicle is "serviced" by the dealer.
    You want to try a Wal Phillips fuel injector. It's probably quite
    reliable being basically a gravity fed tap and butterfly throttle on a
    bit of inlet tract. But mixture is so messed up that it's really only
    fit for use on speedway/grasstrack using methanol which can tolerate
    very rich "safe" mixtures.
    http://www.racinglambrettas.com/howthetdidit/walphillips.html
    Why bother? It's still way down on power. Just get a LET and crank up
    the boost.
    Nissan's turbo motors can all take double the makers rated power on
    stock internals.
    Supra will go to triple.
    GM USA have issued a set of notes on how to get 800bhp from an Ecotec
    with big turbo. The key mods are lube system.
    Peter Hill, May 12, 2011
  16. Tim
    Hog. Guest
    The first thing to do with an R100 mono is swap the carbs
    Hog., May 12, 2011
  17. "Fewer often". Hope that helps to clear it up.
  18. Ditto. Especially with the R100 barrels/pistons/heads/carbs fitted.
    Ditto. Ex N.Wales Plod. I really liked the narrow Plod panniers.
    Mine never had a problem, but the alternator was a bit marginal with any
    extra lighting.
  19. Ah well, the later airheads didn't do too well on fuel consumption,
    which was a surprise to me, as mine (R7 80RT converted to R100)
    regularly averaged 50mpg.
  20. Tim
    Cab Guest
    I'll opt for "often". Sounds nicer.
    Cab, May 12, 2011
