fuel in cylinder - hydraulic lock
Discussion in 'Motorbike Technical Discussion' started by jrallen, Jul 8, 2006.
  1. jrallen
    jrallen Guest
    Folks,
    I have a '94 Honda VFR750 with about 10,000 miles. I bought it recently
    from someone who hadn't ridden it for a few years, rustproofed the tank
    with POR-15 (great stuff!), thoroughly tore down and cleaned the
    carburetors and replaced the fuel filter. I've been riding it for a
    couple of months now, and about a week ago noticed some drops of fuel
    on the garage floor, dripping from the fuel pump. Closer investigation
    reveals that it seems to be coming from the plastic housing around the
    fuel pump itself. Not sure if it's related to my problem, but it may
    be.
    Anyway, I tried to start it yesterday morning, and it went
    whirr-whirr-BAM! Wouldn't crank when I tried again, so I put it in
    gear, rocked bike back and forth a couple of times, put it in neutral,
    and it then turned over and started, but had a misfire.
    Checked the oil when I got home from work, and it's overfull - bad
    sign. Try to start it again, and another whirr-whirr-BAM episode. The
    BAM sounded like knocking two hammers together. I pull the plugs and
    see that cylinder #1 plug is wet, and the top of the piston is shiny,
    unlike the other three which are dark with carbon. Put it in 6th gear
    and rotate the wheel. Piston #1 reaches top of stroke and sprays liquid
    gas out the spark plug hole. Continuing to move wheel, more resistance
    is felt at piston #1 bottom dead center.
    Removed tank and cranked with starter this morning. Seems smooth as gas
    continues to spray out cylinder 1 for a while.
    I assume the next step is to pull the carbs, open the float bowl for
    #1, look for debris and thoroughly clean it.
    Questions:
    Should I go ahead and replace the fuel pump? Do they leak when they go
    bad?
    My current theory is that I'll find a piece of rubber from the fuel
    pump diaphragm jamming the float needle. Does this make sense?
    How do I know whether or not I bent something from my starting
    attempts?
    Lastly, what should I have known or done to discover this issue
    earlier? I think I'm going to start checking the oil on at least a
    weekly basis from now on.
    Thanks in advance for your help.
    Regards,
    John R. Allen
    Bainbridge Island, Washington, USA
  2. First thing I'd do is change the oil. I can't believe you cranked it
    again a second time after you discovered the diluted oil and
    hydraulic lockup. Well yeah, I can and I might have done it
    myself if I was upset by the problem but I suspect this was not a
    good thing to do.
    If it were me, I think I'd change the oil, get rid of the leak, check
    the compression, listen for disturbing noises then if I thought it
    was OK, try to run it and see what happened.
    If it was running badly or making new noises I'd shut it down again.
    If it ran OK, I'd run it a while then change the oil and filter and
    look for any metal bits or powder in the old oil and filter.
    Not sure that's the right course of action, but after I finished
    cursing myself, the bike and the world in general it's probably
    the course I'd take.
    Rob Kleinschmidt, Jul 8, 2006
  3. Sounds like the intake was full of gas, the cylinder was empty, you
    tried starting it the valve opened, cylinder filled with gas then locked.
    any gasoline leak is bad, if the fuel pump is cracked then replace it.
    or a piece of por15
    when the engine seizes or starts sounding like an old threshing machine
    you'll know.
    don't you have a fuel shut off valve/petcock on this bike? It is supposed
    to have one I thought. Get in the habit of turning it off when you park
    the bike.
    Ted
    Ted Mittelstaedt, Jul 8, 2006
  4. jrallen
    tg Guest
    Before doing to much, I would remove any concern over that BAM you described
    as sounding like 2 hammers - may be something more serious than a backfire
    although you may have already determined the cause. (as I read the message
    my first thought was a broken rod or piston or bent valve but you say the
    piston is moving ok, so I scrapped most of that thought).
    In any case, you may want to try pulling the spark plugs and use the starter
    to turn it over - do all the mechanical movements sound smooth - no banging,
    grinding, odd sounding scratching or other odd noises. Then try it turning
    it using the rear wheel to eliminate the starter noise itself. If you have a
    compression gauge, I would get a reading from each cylinder. If the engine
    components sound correct, and the compression is good, then I'd start work
    on the carbs / fuel pump / gas leak issue.
    tg, Jul 8, 2006
  5. jrallen
    jrallen Guest
    Yeah, well, I can't believe I did it either. A case of overactive
    wishful thinking.
  6. I've done worse in moments of frustration. Hope it works out OK.
    I'd change the crapped up oil before I did more experiments.
  7. jrallen
    Wudsracer Guest
    I think you ought to check the oil every time you run the machine. If
    the crancase is too full (as when the bottom end fills with gas), you
    can blow all the engine seals.
    Jim
    Wudsracer, Jul 8, 2006
  8. jrallen
    Leon Guest
    I know someone who had a bent con rod caused by hydraulic lock. He had
    to strip the engine and replace it.
    Leon
    Leon, Jul 9, 2006
