Fuel economy and hybrids
Discussion in 'Australian Motorcycles' started by JL, Mar 3, 2010.
  1. JL
    JL Guest
    JL, Mar 3, 2010
  2. Their figures don't add up either
    they claim 1.9 litres per 100 kilometres with a 12 litre tank gives it a 250
    kilometre range
    Not to my addition, which comes to about 630 kilometres a tankful and that
    is only running the generating motor
    George W Frost, Mar 4, 2010
  3. JL
    CrazyCam Guest
    That does, indeed, sound like what is happening.
    I wonder if it was intentional, or if they thought that the vehicle
    would be able to proceed purely under the petrol system's generated
    electricity, and only found out at testing that it wouldn't.
    It would seem that their claimed fuel consumption claim is rather sneaky....
    not counting the electricity shoved into the batteries before it starts.
    regards,
    CrazyCam
    CrazyCam, Mar 4, 2010
  4. JL
    JL Guest
    Possibly, a less cynical reading would be that the form factor clearly
    calls it out as a city car and hence they aren't expecting you to take
    it on the highway, so you'll be charging it several times per tank of
    fuel (given average distance travelled for that sort of car was circa
    40Km per day - IIRC).
    If you counted the cost of charging the batteries you'd be lucky to
    move the consumption rate ie convert $2.50 worth of power spent
    charging it into an extra 2litres of fuel consumed for the same range
    and I doubt that moves the consumption far
    JL
    JL, Mar 5, 2010
  5. JL
    theo Guest
    On another angle of alleged low-emission vehicles there was a snippet
    on the news this morning saying that if every household in Oz had a
    main-charged electric vehicle, we would need to double the number of
    coal-fired power stations in the country. Another item said that the
    two new proposed power stations for NSW would emit greenhouse gases
    equal to the current NSW vehicle fleet.
    Do we really want coal-powered electric cars?
    Theo
    theo, Mar 5, 2010
  6. JL
    JL Guest
    I'd prefer nuclear powered electric cars and shut down the coal
    powered stations, thanks.
    JL
    JL, Mar 5, 2010
  7. I'd prefer nuclear powered electric cars and shut down the coal
    JL
    I am with Mister Littlejohn on this issue
    George W Frost, Mar 5, 2010
  8. Yeah - I was listening to that when it went to air.
    The concept of being able to tell your car whether you knew you only
    needed to travel 20km the next day to and from work and therefore the
    car could dump power back into the grid, or altenatively you knew you
    had a long trip and you grabbed full power down is a nice concept.
    We still need to get this power generated cleanly though. Cold fusion
    anyone? Or maybe a good Timex clock mechanism?
    Kev
    Kevin Gleeson, Mar 5, 2010
  9. JL
    theo Guest
    I wonder how much you lose on the transfer in charging the vehicle and
    then feeding it back to the grid though. I would think probably in the
    order of 20% or more. This loss is literaly going up in smoke.
    I try to mange my home power as best I can. My meter reads power used
    by time of day/rate and power fed back into the grid by my solar
    cells. I read it daily. OK, I'm retired and need to fill in my time.
    My currrent daily usage is around 20-24Kwh per day, with close ot 45%
    at off-peak rates and less than 10% at peak rates (the solar panels
    mostly generate power at peak rates). My power costs for February was
    $3.47 per day. An electric car would likely double that usage. Just
    how much does an electric car use per km? At what speed. For me, an
    electric vehicle would need to be able to travel 100+ kms between
    charges with half of the distance at highway speeds. To drive my ute
    100 kms costs $11.40, and burns no coal.
    Theo
    Theo
    theo, Mar 5, 2010
  10. JL
    theo Guest
    How about this then
    http://www.mrsharkey.com/charging2.htm
    While studies of the pollution-reducing ability of electric vehicles
    in California are quite favorable, they cannot be applied to the rest
    of the world as a whole. The truth is that when using electricity
    generated from dirty sources such as coal and oil, electric vehicles
    may actually create more of some pollutants than comparable internal
    combustion engine vehicles. A report by the U.S. General Accounting
    Office (GAO) cited a German study that estimated the environmental
    impact of electric vehicles with two distinct energy mixes: one
    comprised of only 49% coal-fired electricity, and one comprised solely
    of coal-fired electricity [1]. The estimates provided by the study are
    given in table 1. Assuming that 49% of an electric vehicle's charging
    energy being derived from coal, the study found that electric vehicles
    would cause comparable levels of nitrogen oxides and carbon dioxide to
    be emitted, and that sulfur oxide emissions would increase by a factor
    of 10 [1]. Furthermore, when assuming that an electric vehicle is
    charged with 100% coal-fired electricity, the study estimated that the
    electric vehicles would emit 150% more carbon dioxide, 250% more
    nitrogen oxides, and 2400% more sulfur oxides than a comparable
    internal combustion engine vehicle [1].
    [1] Electric Vehicles: Likely Consequences of U.S. and Other Nations'
    programs and Policies. (1994). In Gateway Japan. [20 November 1995].
    I think Oz grid electricity production is around 80% coal.
    Theo
    theo, Mar 8, 2010
  11. JL
    G-S Guest
    Lots of Australian electricity production uses brown coal and not black
    coal and that creates more pollution again.
    G-S
    G-S, Mar 8, 2010
  12. JL
    theo Guest
    Brown coal is like burning damp cow-pats. It may even be damp cow-
    pats.
    Theo
    theo, Mar 8, 2010
  13. Fraser Johnston, Mar 17, 2010
  14. JL
    hippo Guest
    Well, until you start doing the sums for a one or two seater four wheeler,
    that offers comparable performance and frequently uses it anyway. Cheers
    hippo, Mar 18, 2010
  15. JL
    JL Guest
    <Baffled look> Why on earth would you even be caring about the fuel
    consumption of a serious sports bike ? Do they even measure the fuel
    consumption of a Ferrari ?
    If it was a CB250, sure.
    And for an engine putting out what 120Kw per litre capacity or
    thereabouts I think that's pretty reasonable fuel economy btw.
    JL
    JL, Mar 18, 2010
  16. JL
    GWD Guest
    Yes, it's the no free lunch thing - if you want power you need to burn
    fuel. Engine design is about finding better ways to burn the fuel.
    GWD, Mar 18, 2010
  17. And when you start to factor tyre and servicing costs in as well. I
    recall I worked at one stage on the Budgie, I was burning as much
    money on tyres as I was on fuel, per km.
    Kev
    Kevin Gleeson, Mar 19, 2010
  18. In aus.motorcycles on Fri, 19 Mar 2010 22:16:03 GMT
    THe Noggie gets about 320km for 19l around town, so that's 5.9l/100km
    or 16.8km/l. The Mighty Scooter does about the same, but $60 tyres
    every 15,000 are cheaper than $220 tyres every 15,000!
    Beign a twoey the scooter's easier to service but the Norge doesn't
    need a litre of bloody expensive 2 stroke oil every 1000km!
    But then if I'd wanted cheap transport I'd not have chosen a heavy
    1200 or a hot two stroke. The Bolwell scooters seem to run on the
    smell of other people's petrol.
    Zebee
    Zebee Johnstone, Mar 20, 2010
  19. I was melting budgie rears at $300 every 2500km for a while, then
    decided that I really need to go to a harder compound . . . 5000km I
    don't mind but 2500km was a bit excessive. Especially as I was riding
    100km per day. But they did build a racetrack to my front door, the
    bastards.
    Kev
    Kevin Gleeson, Mar 20, 2010
  20. In aus.motorcycles on Sat, 20 Mar 2010 12:24:42 +1030
    Probably less stressed than the Norge in Sydney traffic.
    If I don't ask it to lanesplit for 1m at a time, it does better.
    Zebee
