fuel cap sticking
Discussion in 'Australian Motorcycles' started by Mad-Biker.com, Mar 6, 2004.
  1. on me cbr600d4i the fuel cap seems to get stuck down, and needs a fair bit
    of force to pull it with the key, sometimes it feels like the key will snap
    I pull that hard on it...
    I lubed the hinge up with silicone spray..
    what is causing this and how can I fix it?
    cheers
    www.mad-biker.com
  2. Mad-Biker.com
    Uncle Bully Guest
    I had a similar problem with the key not turning all the way (the catch kept
    sticking preventing it from turning). I actually twisted my key opening it,
    but after some well placed dabs of oil (everywhere). It fixed it.
    Petrol probably has some effect on the moving parts of the cap cause it to
    stick
    Uncle Bully, Mar 6, 2004
  3. Mad-Biker.com
    Smee Guest
    See a doctor now!
    Smee, Mar 6, 2004
  4. Mad-Biker.com
    FuTAnT Guest
    Just try some rubber safe (ie, like chain lube) lube on the hinges and in
    the actual key hole as well. It often gets sticky with the mixture of either
    petrol or water getting in when it's raining. The Finish Line lube is great
    for things like this. Doesn't help to put a few drops down your ignition key
    hole every now and then, since they tend to stick after a while.
    Cam
    '03 954
    FuTAnT, Mar 6, 2004
  5. Mad-Biker.com
    Mike.S Guest
    try some wd40 down the keyhole, help the mechanism inside if its not retracting the little latch enough
    Mike.S
    Mike.S, Mar 6, 2004
  6. Mad-Biker.com
    Dr.Shifty Guest
    The problem with using oil sprays on locks is that they hold any dust and clog
    up the lock. Use a dry spray, like Selleys teflon spray. The dry stuff won't
    glug up the lock.
    Kim
    Dr.Shifty, Mar 6, 2004
  7. Mad-Biker.com
    Johnnie5 Guest
    its rusted shut from lack of use
    ride more often
    Johnnie5, Mar 6, 2004
  8. Mad-Biker.com
    Just Al Guest
    Graphite powder works wonders.
    Just Al, Mar 6, 2004
  9. Could be really good fuel economy?
  10. Checked the mechanism and the sealing rubber as well?
    Hammo
    Hamish Alker-Jones, Mar 6, 2004
  11. Will the teflon make my clutch slip?
    Hammo
  12. Mad-Biker.com
    Dave ZZR 600 Guest
    pour a can of wynns lock release in your engine oil
    Cheers,
    1990 ZZR 600 d1
    1991 EB Falcon wagon
    1969 ZC Fairlane
    admin@loopback $LOGIN@localhost
    $LOGNAME@localhost $USER@localhost $USER@$HOST -h1024@localhost
    Dave ZZR 600, Mar 6, 2004
  13. Mad-Biker.com
    Rod Guest
    You can check the alignment of the cap assembly in relation to the hole,
    swelling of the rubber seals and the cap hinge, to make sure it isn't
    binding. To put less stress on the key when unlocking the cap press down on
    the cap itself to take some load off the lock tongue. It doesn't hurt
    sometimes to remove the cap assembly, clean out the gunk underneath it and
    put some graphite or other dry lubricant in the hinge, lock and key barrel
    to stop it sticking and check the alignment of the cap when reinstalling it.
    Rod, Mar 7, 2004
  14. Mad-Biker.com
    Dr.Shifty Guest
    You mean you ride so fast you have to hang on to the fuel cap for safety?
    Kim
    Dr.Shifty, Mar 7, 2004
  15. Mad-Biker.com
    Black Bart Guest
    Only if you use it too jerk off.
    Black Bart, Mar 7, 2004
  16. Hey! I don¹t pick on your riding style!
    Hammo
    Hamish Alker-Jones, Mar 7, 2004
  17. I see it has worked on the "o" key already!
    Hammo
  18. Mad-Biker.com
    Gary Woodman Guest
    Also makes an effective grinding paste, according to a locksmith I
    once knew. He loved oily locks!
    Gary
    Gary Woodman, Mar 7, 2004
  19. Check your vent tube or whatever is not blocked and creating a vacuum
    inside the tank. You'll probably hear a hiss when you pop the lid if it is.
    Pisshead Pete, Mar 7, 2004
  20. Mad-Biker.com
    Wocka Guest
    My key started having issues turning the lock to open.
    Graphite powder worked a treat.
    Wocka, Mar 7, 2004
