FS: Wife, two cats... Erm...
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Sep 8, 2005.
  1. Wicked Uncle Nigel
    frag Guest
    Andy Bonwick? He'z just ziz guy, you know?
    When I machined Mt Everest millions of years ago I used Titan as the
    bit, and rotated the earth around it.
    Thats using a fucking angle grinder!!
    frag, Sep 8, 2005
    #61
  2. Wicked Uncle Nigel
    frag Guest
    tallbloke? He'z just ziz guy, you know?
    If [1] weighs 3 tonnes and you bolted it into a lathe I'm Bears fairy
    godmother...
    frag, Sep 8, 2005
    #62
  3. Wicked Uncle Nigel
    frag Guest
    I'm waiting for the "these lathes are small, those are faaaar away"
    line.
    I mean, one used for milling little bits of metal, and one which bolts
    onto a 8 foot diameter metal thing to cut lumps out of it, calling them
    both lathes is technically correct, but byjesus, scale man, *scale*!! :)
    frag, Sep 8, 2005
    #63
  4. Wicked Uncle Nigel
    frag Guest
    The Older Gentleman? He'z just ziz guy, you know?
    Senior? Its happened to me for years.... oh wait, you means senile. As
    you were :~)
    frag, Sep 8, 2005
    #64
  5. Wicked Uncle Nigel
    AndrewR Guest
    Whatever you do Bear, don't wish for new legs!
    AndrewR, D.Bot (Celeritas)
    Kawasaki ZX-6R J1, Fiat Coupe 20v Turbo
    The speccy Geordie twat.
    AndrewR, Sep 8, 2005
    #65
  6. Wicked Uncle Nigel
    muddy Guest
    godmother...[/QUOTE]
    get yer tutu on then.
    This is similar to what I used to work with.
    http://www.power-technology.com/contractors/powerplantequip/ge_power/ge_p
    ower2.html
    The spinning bit is roughly 12 tons and Westinghouse in Sunnyvale had a
    lathe that could spin it.
    muddy, Sep 9, 2005
    #66
  7. Wicked Uncle Nigel
    tallbloke Guest
    You tell us.
    tallbloke, Sep 9, 2005
    #67
  8. Wicked Uncle Nigel
    frag Guest
    AndrewR scribbled:
    ROFLMAO, you bastard!
    frag, Sep 9, 2005
    #68
  9. Wicked Uncle Nigel
    frag Guest
    muddy scribbled:
    Nah, I'm sorry. Thats maybe 10~15 foot high when built, I'd imagine the
    flywheel on that other engine is taller than that.
    Bear can breathe again.
    frag, Sep 9, 2005
    #69
  10. Wicked Uncle Nigel
    muddy Guest
    Bear can breathe again.[/QUOTE]
    The low pressure wheel is bigger still. Somewhere around 20' in dia.
    muddy, Sep 9, 2005
    #70
  11. Wicked Uncle Nigel
    tallbloke Guest
    Here's something relevant which you'll dismiss because it doesn't actually
    quote the regs. It does touch on vibration issues though.
    http://www.engineeringtalk.com/news/wds/wds113.html
    ***In response to increasingly stringent health and safety regulations***
    applied to the manufacturing and processing workplace, WDS has introduced a
    new range of antivibration products that reduce both high and low resonant
    frequency vibrations.
    The importance of the product range to UK industry is highlighted by research
    that shows low cost antivibration fittings can: increase the productivity of
    machines and reduce their maintenance requirements; improve the working
    conditions and job satisfaction of operators, leading to higher personal
    productivity; and improve the operating environment by reducing noise.
    As well as reducing noise and movement from within a machine, elastomer
    isolation washers can reduce resonant frequency vibrations transmitted to or
    from
    ***fixing bolts used for securing machinery to floors and work surfaces***
    By the way. You see those big holes in the corners of the pedestal castings
    of nearly every lathe , milling machine, pedestal drill, borer, 5 axis
    machining centre and large grinding machine you've come across?
    Well they're not for pushing tent pegs through or chaining your bike to.
    Now **** off and annoy someone else you clueless ****.
    #71
  12. Wicked Uncle Nigel
    MikeH Guest
    There's a secret power-up in UT and when you use it all your opponents
    have their weapons taken away on Health and Safety grounds.
    MikeH, Sep 9, 2005
    #72
  13. Wicked Uncle Nigel
    tallbloke Guest
    Lets see, so many to choose from:
    Noise and vibration regs....
    Fixing of heavy items in the workplace....
    No. **** you, I'm not going to wade through boring stuff to teach you what
    you should already know if you are the half well trained engineer you'd like
    to think you are.
    Go and sit on an unballasted sub with Nigel and try to catch the unbolted
    lathe as it turns turtle.
    #73
  14. You mean you don't have a corkscrew in the lounge as well[1]?
    How else would I be able to open the next bottle of port without having
    to move from the sofa!
    Phil.
    [1] Unless Cheryl has 'tidied' it away. Then I actually have to stand
    up and reach into the drawer..
    Phil Launchbury, Sep 9, 2005
    #74
  15. Ah - like an MCSE then?
    Phil
    #75
  16. Wicked Uncle Nigel
    frag Guest
    Bear? He'z just ziz guy, you know?
    Your wish is my command
    *DING*!
    frag, Sep 9, 2005
    #76
  17. MCSE has a picture of Barney on it. Meant to convey more gravitas than a
    simple conventional smiley, see?.
    Soylent Green, Sep 9, 2005
    #77
  18. Wicked Uncle Nigel
    snip>
    I can list plenty of ways to mount machines, it's something my company
    frequently have to do and as a site engineer it's part of my day to
    day responsibilities.
    snip>
    I'll **** off and I'll accept I'm a **** but I'd dispute I'm clueless.
    I can provide a nice healthy CV that'll get me a job as either a
    machinist or a site engineer (my present job) at a range of different
    companies. It might seem odd to you but people I've done work for
    actually respect my opinion and are willing to fly me all over the
    World to get them out of the shit.
    Now either back up your statement about safety regulations or admit
    you were just bullshitting in the hope that nobody here would catch
    you out.
    Andy Bonwick, Sep 9, 2005
    #78
  19. Wicked Uncle Nigel
    mb Guest
    Welders qualifications aren't up to much either. They may have to weld
    something for a specific job, but most of the time, they have their
    quals kept up to date by people like me just putting their name on an
    inspection report.
    Of course, anybody could have welded it but somehow this sort of thing
    is routine and accepted by clients etc.
    Oi, you're a bad man. I have to do retests every five years to keep my
    quals - and being qualified in 5 different NDT disciplines means a lot
    of retests.
    Ask your doctor what he has to do.
    mb, Sep 9, 2005
    #79
  20. Wicked Uncle Nigel
    Ben Blaney Guest
    Actually, I don't. I get around in Black Hawk Helicopters, milair
    C-130s, and BA Club Class (from where I write). I get paid more than
    I'm worth, and I've got more women floating around than I can shake a
    stick at (and I'm not paying for any).
    How's life as a unix-weenie in the grim norf?
    Ben Blaney, Sep 9, 2005
    #80
