FS: Wife, two cats... Erm...
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Sep 8, 2005.
  1. Wicked Uncle Nigel
    Damn, I was just about to mention the brass matchbox holder I made at
    school - I'm sure I was onto a winner with that one.
    Krusty, Sep 8, 2005
  2. Wicked Uncle Nigel
    Well post a link to a photo and we'll have a vote on it.
    Andy Bonwick, Sep 8, 2005
  3. Wicked Uncle Nigel
    Krusty, Sep 8, 2005
  4. Wicked Uncle Nigel
    tallbloke Guest
    Yeah. Whereas Mr gobshite super-machinist is talking about a mobile boring
    jig he fastens onto a stern tube and skims little cuts out, I'm talking
    about bloody great pump casings weighing several tonnes spinning round at
    120 rpm while I rip 12mm depths of cut off at Metal Removal Rates which
    would make his eyes water.
    tallbloke, Sep 8, 2005
  5. Wicked Uncle Nigel
    Ben Blaney Guest
    I love it when stuff like this happens.
    Ben Blaney, Sep 8, 2005
  6. Wicked Uncle Nigel
    tallbloke Guest
    You lead such a dull life
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, tallbloke
    Which relates to the point you were trying to make about the small lathe
    on the trailer being useless how, exactly?
    Just out of interest, like.
    and Ducati Race Engineer.
  8. Pink, you mean? Sort of 'Gay Machinists do Africa'?
    Grimly Curmudgeon, Sep 8, 2005
  9. Wicked Uncle Nigel
    tallbloke says...
    You obviously haven't seen the work they did where Andy served his time.
    Clue: they built cruise ship engines for Rolls Royce.
    Lozzo, Sep 8, 2005
  10. Wicked Uncle Nigel
    MikeH Guest
    Depends what tool he's using to rip, doesn't it?
    MikeH, Sep 8, 2005
  11. Wicked Uncle Nigel
    tallbloke Guest
    Whoopsydoo, The firm I served my time at build bigger ships engines than
    Rolls Royce ever have.[1] They also build the particle accelerator
    chambers at CERN and the biggest nuclear boiler feed pumps in the world.
    It makes me laugh when Bonners spouts about heavy chain blocks and then
    says he's not getting into a pissing competition. Still, he had my respect
    as an engineer until he became so condescending towards others.
    [1]here's one of the smaller ones ;-)
    http://www.shipsnostalgia.com/gallery/data/500/336sulzer_engine_port.jpg
  12. Wicked Uncle Nigel
    MikeH Guest
    That's the original BMW K100 engine, before they realised the scale on
    the drawing was in millimetres and not feet.
    MikeH, Sep 8, 2005
  13. Wicked Uncle Nigel
    tallbloke Guest
    As I said earlier, it's a matter of the ratio of the weight of the
    component to the machine and it's damping. Obviously, the balance is a big
    factor too. In the case of large pump casings there are large out of
    balance forces, and the key to preventing vibration striations on the
    machined surface lies in the correct pressure being applied between the
    tool and the job. That the fucking great machine it's spinning round on
    will be properly shimmed and bolted down goes without saying. This is
    where finding the right tradeoffs in tool life, MRR and surface speed sort
    the properly qualified machinist from the hobbyist. No offence intended to
    you Nigel, but when you are making items at home, you aren't under the
    same time=money and tool insert life constraints that you deal with in a
    production environment.
    A lathe mounted in a trailer will be fine for smallish components made
    from bar stock and tube, but you may well get 'ringing' problems if you
    try to skim brake discs for example, or small cuts along long shafts made
    from harder materials. It all depends what resonant frequencies get set up
    when machining, and in general, the heavier, and more solid, and better
    damped the machine is, the less vibration problems you'll suffer, given
    that the bearings in the machine and the cross slide shimming etc is all
    good.
  14. Using the patented Mavis Beacon "Hunt&Peck" Technique, tallbloke
    Of course not. The speeds and feeds I use bear absolutely no resemblance
    to those used in a commercial shop. I optimise mine for tool life and
    reduction of strain on my ageing, unbolted-down machines.
    Not if you spend the time to **** about to find the speeds where you
    don't. Or set up a travelling steady. And that's what home shop
    machinists do.
    Agreed. So we now agree that the trailer mounted tools are in fact
    useful, and we both want them. Right?
  15. Wicked Uncle Nigel
    tallbloke Guest
    Just to revisit this in the light of your subsequent comments.
    How can they be fastened down with enourmous chain blocks if they aren't
    secured to anything?
    You seem to have undermined your contentions about your machines being
    fastened to thin air and submarines hovering gently in the aether just
    above their dry-dock moorings.
    You were just being an argumentative twat for nothing as usual weren't
    you? ;-)
  16. Wicked Uncle Nigel
    Donald Guest
    ROFLMAO
    Good old BMW, easy access as ever, although they seem to have ditched
    the ladders on my K75.
    Donald, Sep 8, 2005
  17. Wicked Uncle Nigel
    tallbloke Guest
    To an extent yes. Factory shop machinists use travelling steadies and have
    to **** about with speeds and feeds too you know. I'm just pointing out
    that the better the machine is fastened to the rest of the world, the less
    vibration problems you'll suffer.
    Ok have it your way. bid on it. Make sure it ain't too wide for british
    roads first though ;-)
    You can always reduce the tyre pressures on the trailer to change the
    vibration frequencies, but if you're machining on the move, make sure it
    doesn't cause unusual wear patterns on your tyres.
  18. Wicked Uncle Nigel
    So says you. I reckon you're the Walter Mitty of 'O' Level metalwork.
    sweller, Sep 8, 2005
  19. Wicked Uncle Nigel
    Heh, you're showing yourself up as more and more of a clueless ****
    every time you post.
    Do a search for NEI or APE Allen, you'll see the type of equipment I
    worked on in both the heavy machine shops and the fitting shops.
    I'm a long way from being a 'super-machinist' but I try to avoid
    making sweeping statements that are so far away from being correct
    it's almost painful. You managed to do that and then when challenged
    on it you made another very brave statement about safety regs which I
    notice you haven't been able to back up yet. Any proof will do, as
    long as it's a regulation and as such legally binding.
  20. Wicked Uncle Nigel
    snip>
    The point I was trying to make about chain blocks is that 3 tonnes is
    very small. You prattle on about 3 tonne castings as if they're big
    lumps of kit but they're not. You also posted that equipment had to be
    secured firmly when it doesn't. I've no doubt it'll be a long wait for
    the proof about safety regs stating that machines have to be secured
    onto concrete bases but that's not going to be such a shock.
    Btw, posting links to marine engines is great but did you work where
    the engine was manufactured and if so did you work on similar sized
    engines? I might be way out here (if so I'll apologise now) but at a
    guess you might have worked at Sulzer pumps in Leeds and I didn't
    think they made marine units there.
