I really wanted one of these and picked this one up recently. Spent a load of time and cash on fettling only to find that the lefthand kickstart aggravates the arthritis in my left hip so it has to go. Its a 1991 TS350 onna J plate. These Czeck 2 smokes have a reputation for reliability so it will make someone a nice commuter ratbike or winter hack. Spares are not a problem. Rides well, pulled nicely up to around 75 on the M5 today so plenty enough for a commuter. Legal for 33bhp restricted licences. Offering it here before putting it on fleabay, UKP350 sounds about right, located near Weston Super Mare. The good bits :- Only 17100 recorded miles, and the engine wear etc is consistant with this. I opened it up to fix a noise and found that one cylinder was short of a roller in the little end so I fitted nice new caged rollers both sides. New battery, new cables for clutch, throttle and front brake. Long tax & MOT. Tidy for the year. The bad bits :- Seat tear repaired with duck tape (they all do that) Dent in the tank and front mudguard, nothing serious. Some corrosion on the indicator stalks and chrome trims. Rear tyre will need replacing soon. Number plate chipped. Nonstandard pipe from airbox to carb. Slight incontinence from the primary chaincase cover, my fault for fitting a new gasket without using sealant - easy enough to drain and fix if a drip per day bothers you. email crn (at) netunix (dot) com
