FS: MZ ETZ 300
Discussion in 'Classic Motorbikes' started by sweller, Oct 21, 2003.
  1. sweller
    JH Guest
    Quite how long various bits last, gods only knows, but it does sound a hoot.
    Perhaps they'll be the next big thing after monkey bikes become passe...;-)
    Jon H.
    JH, Oct 22, 2003
  2. sweller
    JH Guest
    If i can get my new book of Barclaycard cheques in the next couple of days
    I'll race you too it. Trouble is, if it's gone, I'll prolly start sniffing
    round your GN too. Now there's a bike i really would look silly on...
    JH
    JH, Oct 22, 2003
  3. sweller
    GN250?
    Horrible.
    Strangely, I quite fancy a TU250X, mind...
    darsy, Oct 22, 2003
  4. sweller
    Platypus Guest
    Prolly the 300 bottom end is stronger/more modern than, say, a nold 125.
    Bigger, see?
    Platypus - Faster Than Champ
    VN800 Drifter, R80RT
    DIAABTCOD#2 GPOTHUF#19
    BOTAFOS#6 BOTAFOT#89 FTB#11
    BOB#1 SBS#35 ANORAK#18 TWA#15
    Platypus, Oct 22, 2003
  5. sweller
    Big Tim Guest
    I can accept that.
    Bigger = Better, very true
    Just curious about the cc sizes.
    "When I was a lad" your regular two-stroke engine sizes were 50cc
    (mopeds) 100cc & 125cc commuter thingies. Suzuki's GT185cc, Yamaha's
    RD200 were the next step up. Then everyone did 250cc and 350cc, until
    the KH400 and RD400 came along. etc, etc.
    Admitedly MZ (and CZ's) were perhaps a law unto themselves, so they
    developed the next optimal engine size - as they saw fit - of 300cc.
    But a 404cc conversion shirley must be from some racing series or
    something?
    Big Tim, Oct 22, 2003
  6. sweller
    but Simon, it was made in a Communist country...
    darsy, Oct 22, 2003
  7. sweller
    There are a number of aftermarket 300cc kits available, it's also
    possible to bore out a 250cc to the limit and slap in a 300cc piston.
    It's not one of those. Hence the 'genuine' reference.
    As to the 404cc, I suspect that's the biggest readily available other
    make piston that works with the ports. When the bore is taken out to
    accommodate, it equates to 404cc.
    Although I'm /sure/ I once saw a GDR plod bike marked as 400cc. Probably
    didn't...
    The MZ racing, IIRC, is strictly 250 with little in the way of chassis
    modifications. In race trim they can embarrass a lot of bikes.
    In non-race trim they embarrass a lot of owners.
    sweller, Oct 22, 2003
  8. sweller
    Platypus Guest
    Rounding error.
    GT185=182cc
    RD200=195cc
    RD250=247cc
    RD250LC=249cc
    RD350=349cc
    RD350LC=347cc
    KH400=399cc
    RD400=398cc
    MZ125=123cc
    MZ250=243cc
    MZ301=300cc
    However, the 404 is a conversion, not a model designation from the
    factory's marketing department. So it will, at a guess, have the 301's
    stroke, and a stupidly oversize piston. I don't know the 301's bore and
    stroke, but at a guess, the dimensions will be fairly close to square.
    So:
    300cc = 74mm x 70mm
    404cc = 86mm x 70mm
    86mm is fucking big for a 2-stroke. An 80mm stroke would give
    300cc = 69mm x 80mm
    404cc = 80mm x 80mm
    Even with a long-stroke engine, it's a big piston, and a shitload of
    metal off the inside of the barrel. Hmmm.
    ISTR Jawa having a 400cc 2-stroke single in a crosser.
  9. 'tis tidy, innit. If I had 300 notes to spare I could buy it for me Mother,
    who keeps making noises about wanting a bike again (used to be summat of a
    biker in her yoof, had a 1000 vincent among several others)
    Austin Shackles, Oct 22, 2003
  10. sweller
    Damn good front brake by non MZ standards of good. IIRC it was a brembo iron
    rotor?
    Hog, Oct 22, 2003
  11. sweller
    Big Tim Guest
    <snip general cc sizes of 70s/80s strokers>
    So, you'd not suggest it as sesible for a ride to work, winter hack.
    However, as a piss-taking stealth type thingy...
    Not that I've ever had a bike where what it said on the tin didn't
    match what it'd really do. Not me Mr. Not at all...
    Crossers, law unto themselves.
    Although I was considering a Husky 460cc (IIRC) automatic at one stage
    because I'd broken my wrist and couldn't pull a clutch in. Physio
    finally sorted the problem and I got a sensible 1200 Bandit, as you
    do.
  12. sweller
    Platypus Guest
    Depending on state of tune. If it was a big, soft, torquey thing it
    would be lovely to pootle around on, keep up with traffic etc. OTOH
    something with a powerband 300rpm thick, huge spanny and bakelite
    part-worn Pneumats would be different...
    You've been bad, haven't you?
  13. sweller
    Big Tim Guest
    Today? No.
  14. sweller
    I had one of the very early disc braked export ETZ 250's, they were
    fitted with actual Brembo items (calliper and master cylinder and cast
    iron disc). Later machines had copies made under licence.
  15. sweller
    Platypus wibbled incoherently
    The aircooled and LC RD250s, from the YDS7 of 1970 until the Jap and
    Aussie market RD250LC F2 of 1992, shared the same bore and stroke, which
    brought them out at 247cc.
    The above applies to the 350 variant, from the earliest YR5 in 1970 to
    the last of the Brazilian made LC models in 1994. They were all 347cc
    and shared the same bore and stroke. I've fitted piston kits from 1994
    model LCs into a 1973 RD350 before. The RD400 has the same piston
    diameter, just a longer stroke.
    Correct
    Lozzo
    ZZR1100D, GPZ500S, CBCBCB750RSRSRS
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, KoBV#3.
    www.mjkleathers.com
    Lozzo, Oct 22, 2003
  16. sweller
    Big Tim Guest
    Interesting.
    I know it was a common "trick" to stick the 350 aircooled top-end onto
    the 250.
    So, will a 350 piston kit fir a 400, or is the piston skirt longer (or
    something) because of the longer stroke? Could be useful information
    if I ever get the RD back on the road.
    Or, staying *slightly* on topic, are there any know big-bore kits /
    setups for the RD400. ISTR that Fharon <sp?> did one and that there
    was a water-cooled kit. Or am I thinking of the same thing.
  17. sweller
    Big Tim wibbled incoherently
    BTDT a few times
    The piston kits commonly available for 350LCs have a slightly longer
    piston skirt and this fouls on the conrod of the 400 engine[1], but
    otherwise they are the same in dimensions. You simply have to carefully
    file away a small beak that protrudes from the bottom of the piston
    skirt. There is sometimes a difference in the porting windows in the
    rear of the pistons, the C and D model 400 had round windows, the E and
    F and the LC range had square ones. It makes no difference to a C or D
    if you fit the later pistons, but fitting early pistons to a later
    engine strangles them somewhat.
    You can use DT175MX pistons to take it out to 430cc, but they aren't
    reliable enough unless used in conjunction woth a water-cooling set-up,
    which brings us to....
    Fahron made one, amongst others. I owned a Fahron water-cooled RD400 for
    about 4 days back in 1983, it was an absolute rocket-ship and pissed all
    over tuned 350LCs.
    [1] A longer conrod and wider sweep of the crank web makes this happen.
    The conrod is at a greater angle when the big-end pin is at 90 deg to
    the crank centre, effectively makeing the whole shooting match wider,
    hence the different (deeper) crankcases for 400 models.
    Lozzo
    www.mjkleathers.com
    Lozzo, Oct 22, 2003
  18. sweller
    Jon Harris Guest
    Well, there's Sweller's on the south coast and an even cheaper one on eBay,
    though it does need a bit of work, in Glasgow.
    JH
    Jon Harris, Oct 22, 2003
  19. sweller
    This one?
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=2437914921
    Its a very early one ('de luxe' export model as it has a disc, oil pump
    and tacho). Genuine Brembos.
    Looks as if it needs some work, no MOT, clutch lever, tyres, leaking head
    gasket, electrics and its at £165!!! I'd pay about £50 for one in that
    state. And probably break it.
    I have a manky but good (IYSWIM) 1985 ETZ 300 conversion with an MOT,
    maybe £200 - 250 ish. May put it on Ebay to see what happens.
  20. sweller
    Big Tim Guest
    I wonder if this (square windows) is why when my RD needed a rebore
    and I checked with a Mr R Beckett of the Nottingham Parish[1], he said
    that the ports in the piston didn't need opening up like they used to
    do
    I suppose I'd better get it running again before I try and get clever
    with fancy ideas of tuning it up some more.
    Ta for that, most informative.
    [1] His dad, a Mr T Beckett had meddled about with my internals some
    6-7k miles previously. And a jolly good job he did too.
