FS: BMW K75S with full luggage
Discussion in 'UK Motorcycles' started by Timo Geusch, Apr 1, 2006.
  1. Timo Geusch
    Time to say goodbye to the winter hack, methinks. Something to do with
    an attempt to increase the garage vaccuum again...
    Anyway, here we go:
    H-Plate BMW K75S (the model to have), a mere 100k miles on the clock
    with full luggage, something like 9 months MOT left (can't be arsed to
    dig out the certificate at the moment) and tax until the end of July.
    Full luggage, although some of the clasps have been, erm, modified. As
    has the braking system - the previous owner removed the whole ABS
    system as both the ABS ECU and one of the pumps had given up the ghost.
    One careful owner, and at least nine careless ones. And it's purple.
    *Matt* purple in those areas where the previous owner resprayed the
    fairing.
    Tyres are decent, engine sounds and feels good, gearbox has a slight
    rattle from the idler gear which I believe is normal for high-milers.
    Occasionally "misfires" in second gear on acceleration.
    I've sorted out the "they all do that sir" seized radiator fan, changed
    engine oil, air & oil filter. With the bike you'll get a set of plugs
    and a fuel filter 'cos I couldn't be arsed to replace that one yet.
    It's got me to London and back with a minimum of fuss. Fuel requires
    topping up every 200 miles and that was pretty much it. Oh, and it'll
    also want a clutch cable as the adjuster is broken off at the lever.
    Looking for around 650 quid, which is slightly less than what it owes
    and a hell of a lot less than you'd normally have to cough up for a
    running, MOT'd and taxed 75S. *Especially* for one with luggage.
  2. Timo Geusch
    Timo Geusch said...
    Sounds like just the thing to fill the vacuum in my garage
    Hah, you must have thought I was going fucking senile.
    Lozzo, Apr 1, 2006
  3. Timo Geusch
    "Someone frogging Lozzo" was actually the first thought.
    Timo Geusch, Apr 2, 2006
  4. In uk.rec.motorcycles, Lozzo belched forth and ejected the following:
    ROTFL
    Whinging Courier, Apr 2, 2006
  5. Timo Geusch
    .. Guest
    Now *that's* an image I really don't ever want to encounter
    .., Apr 2, 2006
  6. ....And it looks exactly like this one:
    http://www.de-locht.nl/occasions/K75S.jpg
    Possibly.
    Si
    Mungo \Two Sheds\ Toadfoot, Apr 2, 2006
  7. Timo Geusch
