FS: 96 Thunderace (YZF1000R)
Discussion in 'Australian Motorcycles' started by craigsarah, Nov 22, 2006.
  1. craigsarah
    craigsarah Guest
    1996 Yamaha YZF1000R (Thunderace), Black and Silver
    33005Km, VIN ends with 000195
    Rego ran out in June but it will come with a current blue slip
    (It was at the mechanics since early June)
    Gearbox rebuild zero Km ago (I can't ride it without a license or rego)
    Comes with
    WP rear shock
    Arrow slip on
    Tinted hi-rise screen
    Braided front brake lines
    Oggy Knobs, K&N air filter
    Iridium plugs
    Near new clutch (approx 2000Km)
    Near new 530xw chain and sprockets (less than 1000Km)
    Near new rear tire (less than 500Km)
    $7000.00 ono
    Craig 0415 882733
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. craigsarah
    Fwoar Guest
    where?
    Fwoar, Nov 22, 2006
  3. craigsarah
    J5 Guest
    near central station ;)
    J5, Nov 22, 2006
  4. craigsarah
    craigsarah Guest
    Sorry, it's in Sydney
  5. craigsarah
    JB Guest
    Just out of curiosity, if its only done 33,000k's why would it need a
    gearbox re-build?
    JB, Nov 22, 2006
  6. craigsarah
    J5 Guest
    geez don't you know anything , japaneses bikes are lucky to even get that
    far
    without self destructing ;)
    J5, Nov 22, 2006
  7. craigsarah
    craigsarah Guest
    the previous owner was a wheelie king (in his own mind) and stuffed 2nd
    gear, it would pop out (and back in again)under HARD acceleration at about
    10,000rpm, when I pulled the gearbox apart I found a few of the gears and
    shift fork had unusual wear, so I replaced the lot.
    But while it was at the mechanics I lost my license (until 2008) so the bike
    must go to remove temptation.
  8. craigsarah
    batfastard Guest
    Here's a tip for you...
    When selling a bike, and trying to get the message across that it's
    been well cared for, try to avoid posting images on a photobucket
    account named 'psycho biker'.
    HTH,
    BF.
    batfastard, Nov 22, 2006
  9. craigsarah
    Theo Bekkers Guest
    One of those people that thinks using the clutch to change gears is
    optional?
    Theo
    Theo Bekkers, Nov 22, 2006
  10. craigsarah
    CrazyCam Guest
    Eh? Isn't it?
    regards,
    CrazyCam
    CrazyCam, Nov 23, 2006
  11. craigsarah
    IK Guest
    It's only a year and a half or so. If he was on, say, 9 points, and got
    done for 45 over the limit, that's another 6 points, for a total of 15
    points, which, from memory, attracts a year's mandatory suspension. Put
    the additional 6 months' suspension for the 45 over on top of that, and
    you're well into 2008 then...
    IK, Nov 23, 2006
  12. craigsarah
    craigsarah Guest
    If you get it fixed NOW it will only need the shift fork replaced (they bend
    real easy), if you wait (like I did) it'll cost you a couple of thousand.
    Craig
    craigsarah, Nov 23, 2006
  13. craigsarah
    craigsarah Guest
    doesn't mean I ride like a psycho, just that I am a bit psychotic and I
    ride, well that's what the voices tell me anyway.
    Craig
  14. craigsarah
    J5 Guest
    welll
    you will have to
    *split the cases*
    :D
    J5, Nov 23, 2006
  15. craigsarah
    craigsarah Guest
    It's not a small job any way you look at it, but I have the workshop manual
    and a Haynes manual if you want to borrow them :)
    Craig
  16. craigsarah
    batfastard Guest
    Gearbox rebuild needs the engine to come out and the top end removed
    before you can split the cases.
    If you reckon it's worth the gamble, it's pretty common to leave out
    the two case bolts that sit beneath the barrels so that if you need to
    do the gearbox again you can leave the top end intact.
    However, if this fucks up the main bearings and the crank its your own
    fault for listening to someone on a newsgroup :p
    And if you need a manual, you can find it (as well as the parts fiche)
    on the net if you look hard enough.
    BF
    (wallet now lighter by one YZF topend rebuild and two YZF gearbox
    rebuilds)
    batfastard, Nov 24, 2006
