Frozen clutch, stuck in gear
Discussion in 'Motorbike Technical Discussion' started by PHREAEKIE, Aug 2, 2005.
  1. PHREAEKIE
    PHREAEKIE Guest
    So there isn't really any way the timing could have been messed up whe
    tightening the inner clutch hub? I had the bike in gear and blocked th
    tire up. I was thinking maybe the signal generator rotor on th
    crankshaft may be the problem. But if there is no chance of this, tha
    would be great. Also, just for curiousity, would the whole electrica
    system fail when the circuit breaker trips, or just the ignition?
    will try to start the bike like you have said. I looked at the roto
    and all on the crankshaft today, but didn't really have a chance t
    mess with it or anything. Other than a running inspection, the bike i
    good to go now :)
    Thanks again,
    Bil
  2. No, torquing the inner clutch hub nut will not affect the signal
    generator in any way---unless maybe you loosened the nut that secures
    the rotor onto the end of the crankshaft. You didn't mess with that nut
    did you, trying to turn the engine over with a wrench? In the CW
    direction all that would happen is that you'd be trying to tighten the
    nut that's already tight. If you adjust the valves, you can use that
    nut to turn the engine over, in the CW direction only, with the spark
    plugs out of the engine is best...
    Also, just for curiousity, would the whole electrical
    Everything is dead on my GSXR-750 when the circuit breaker trips.
    That's never happened to me though.
    krusty kritter, Aug 2, 2005
