Hey...MORE GREAT NEWS! I tried all of the suggestions that Krusty gave to me and nothin seemed to work. I was trying everything I could without removing th clutch inner hub because of that nasty nut that is on so tight Finally, I got looking closely and I began to think that this had bee fooled with before. The lockwasher which goes between the washers afte the nut seemed like it had been pryed at with a knife or screwdriver. S I got the girlfriend over and I tried to break it free with a wrench an a 2 x 4 to hold it in place while I broke it loose with the ratche (1.25") I had just bought. Turns out, I didn't break it loose, but did break the little nub which the clutch bolt goes into (yay!). S this really sucks now, but I saw some interesting stuff while I was i there. I looked around briefly and reached over the bike. I watched th shifting mechanism on the side behind the clutch and saw the secto gears wiggle in the upward direction, but were fully jammed up. As soo as I looked on the other side, I noticed what was happening: Th shifting mechanism sector gear which meshes with the sector gear bolte to the cylindrical shifting drum...it just wasn't working right. Coul it be that the little plate (bracket?) behind the device going to th shifting drum...had a screw that wasn't tightened. This device ha about 1/32nd of an inch of clearance and that screw was out about turns. I turned that little sucker till it was tight and now I ca shift all of the gears no problem. I haven't figured out if the clutch is still hard to pull in onl because I need the new inner hub before I can bolt all this back in Once I do that, I think I will get it back to running (oil, cleanup exhaust, etc.) and then remove the cover over the clutch mechanis which pushes the pushrod in and see if I can loosen that screw t loosen the clutch. My main worry is that the clutch already seems to b slightly engaged while starting and running and I am worried tha loosening the tension to adjust it will just make it worse. Is ther anything else I should check to find out why that darn clutch lever i so hard to pull in? BY the way, I have MANY close up pictures of the whole process an problem I found behind the clutch if anyone is interested. You might b able to get a better idea of what I mean and maybe even see what I mea when I talk about all of the tampering I found. So if you ar interested, just send me an e-mail address or something and maybe I ca show you what I mean. I am also gonna have to figure out the problem it is having wit running. The bike seems to want to stall due to low idle at start-u and requires afew punches of the throttle to stay running. Once warm hitting either brake too hard tries to (or does) kill the motor whil riding. The only way I can get it to run right is with the choke o (which keeps the tach at about 3-4 grand). If I fiddle with it to ge it running good, I can get it to settle pretty nicely right around 150 rpms, but it just seems like it isn't running very well. I tried messin with the idle adjustment screw...which just did absolutely nothin except burn my hand. Oh well, at leaste I might be able to ride i soon...gotta get an inspection after fixing the clutch...what a joy. Thanks for all the help guys, Bill
