Frozen clutch, stuck in gear
Discussion in 'Motorbike Technical Discussion' started by PHREAEKIE, Jul 26, 2005.
  1. PHREAEKIE
    PHREAEKIE Guest
    Ok, well I did try to start the bike last night once I put in the ne
    battery. Because the bike is in gear, the nuetral light will not com
    on and the starter will not engage. Hitting the start button simpl
    does absolutely nothing. I have tried rocking the bike to get it out o
    gear and find neutral, no success. I tried jumping the bike, but after
    year and a half of sitting, it probably wont start right away anyway. A
    I said before, the clutch is hard to pull in, but everything seems to b
    in pretty good shape. I am thinking that for whatever reason, my trann
    is stuck in gear and maybe that is keeping me from having a nice, loos
    clutch. I am thinking of taking it to the shop only because I don'
    really know what to do. As I said, I cannot get it out of gear, eve
    with the clutch in, so the bike won't start. When moving the bike, yo
    have to hold the clutch in and it makes it slightly easier to push, bu
    it is impossible with the clutch out. I guess I will try to take a loo
    at the gears inside the tranny today and see if I can't find anythin
    interesting (or broken).
    Thanks for the help! (and the LONG reply...)
    Bill
    By the way, I don't know if this would make too much of a difference.
    removed the cover directly in front of the chain where the clutch cabl
    goes into. I saw the little device that it rotated to push the pushro
    for the the clutch. With this cover off, the clutch felt great, s
    maybe it is frozen in where that pushrod is? I don't know...I just wan
    my baby running...
  2. All of Suzuki's air/oil cooled engines share the same engine
    architecture. I have a 1986 GSXR-750 shop manual here and the same
    parts are used in my
    GSXR as are in your Kan o' Tuna. The engine crankcases were built to
    handle the power of the GSXR-1100, so they are robust and heavier than
    a 600cc motorbike needs.
    If you want to see some pictures of what I'm talking about, go to
    www.partsfish.com and register. Select Suzuki motorcycles and you'll
    see a list of all the Suzuki models. Scroll down to the GSX600 Katana
    and you'll see a list of years. Select 1994. Then you can look at the
    parts fiches for free.
    You cannot see the transmission gears when you take the clutch cover
    off.
    You can see the clutch. If you remove the clutch, you can see the
    shifter
    mechanism.
    The gear shift mechanism is on the GEAR SHIFTING fiche. The shifter
    shaft has a sector gear on the end of it which meshes with another
    sector gear on part #6 which is a ratcheting device that bolts to part
    #5 that is the cylindrical shifter drum. That's what pushes the shifter
    forks sideways to enage and disengage the gears. There are little
    shifter pawls (numbers #7 and #8) that actually do the pushing on the
    shifter drum. One of the shifter pawls might be stuck. That would be a
    bitch, to have to go through a lot of hassle to get at a stuck pawl.
    That ratchet device is just like the ratchet inside a mechanic's
    ratchet wrench, but it's BEHIND the clutch.
    On the other end of the shifter drum is part #23 which some people call
    the shifter star. You cannot get at the shifter star from outside the
    engine. The crankcases have to be split to get at it. Part #18 is a
    detent device that holds the shifter star in whatever gear you shifted
    the transmission into. It's possible for that detent arm with the
    roller on the end to get hung up between gears. Having to split the
    cases to get at the detent arm is a major crock of shit!
    Yeah, I understand what you mean. You get used to having a motorcycle
    that works right and it's a nightmare when it won't start.
    My GSXR750 has a hydraulic clutch, so there's a slave cylinder located
    in the place where you found the little rotating mechanical gizmo. Your
    gizmo just a screw type device.
    I don't know what kind of mechanic you are, whether you would think it
    was a major operation to remove that clutch cover and maybe take the
    bolts out of the clutch pressure plate so there would be no question
    about whether the clutch stack is "frozen" as you suspect. That would
    definitely "unfreeze" the clutch.
    There are about 4 bolts in the pressure plate. If you remove those
    bolts, you have to use brake cleaner to degrease the bolts and the
    holes they go into before you put the bolts back in. If you try to
    torque oily bolts, they will turn forever without making the torque
    wrench click at the specified torque setting. You could ruin the clutch
    inner hub if you try to torque oily pressure plate bolts. That would
    cost major $$$$.
    Once the pressure plate is removed, there is a big nut (about 1-1/4
    inches) that holds the clutch hub onto the transmission main shaft.
    Once the clutch is removed, you can get to the shifter pawls that might
    be stuck.
    Removing the whole clutch may be a major operation for you, I have no
    idea about your mechanical skills, but you need a BIG breaker arm on
    your ratchet wrench to loosen that nut. It's torqued on there at about
    100 foot pounds. And you would need to stop the rear wheel from
    turning. I would just stick a 2 X 4 between the swing arm and the rear
    wheel spokes.
    The other possibility is what I said yesterday. The starter clutch
    might just be stuck, and if you pull that pin out that the reduction
    gear turns on, you can try to turn the idler gear clockwise to see if
    it breaks loose and if you can shift the transmission into neutral with
    the reduction gear out of the way.
    If you can get hold of a shop manual you just might want to study the
    engine and transmission section very carefully before you take your
    "Baby" down to the local $uzuki $tealer$hip and let those guys get
    inside her.
    krusty kritter, Jul 27, 2005
  3. PHREAEKIE
    Bryan Guest
    So does this bike bike have a kick stand safety switch? Just a dumb
    question.
    Bryan
    Bryan, Jul 27, 2005
  4. How much free play is there at the clutch lever? And, do you have any
    information in your owner's manual about how to adjust the free play at
    that clutch release mechanism you saw? There is an adjustment screw
    there, according to the CLUTCH parts fiche. It would definitely help to
    have the clutch release mechanism and cable adjusted correctly.
    Typically, you would have about 1/16th of an inch of free play on the
    cable.
