Front sprocket nuts,,,again.
Discussion in 'UK Motorcycles' started by Lozzo, Nov 10, 2004.
  1. Lozzo
    In order to shift mine I had to:
    A) Position the bike with the front wheel against a wall
    B) Lock the back brake on with a piece of wood jammed in the peg hanger
    C) Select first gear
    D) Wedge the bike with another piece of wood so it wouldn't tumble over
    E) Use a 27mm deep socket on a 2 foot breaker bar with a 6 foot scaffold
    pole on the end and heave like **** on the end of scaffold pole to get
    it to move. In doing so I managed to make the breaker bar bend like
    Robin Hood's bow and lift the bike a couple of inches in the air.
    There's no way that was only done up to 150Nm.
    Why do people insist on over-tightening sprocket nuts like this? I have
    to buy a new nut at 12 quid now because this one is fucked. It wasn't
    damaged in the removal process but you can bet the threads have been
    stretched way beyond their usefulness by the over-tightening.
    Lozzo, Nov 10, 2004
  2. Lozzo
    Eddie Guest
    Instead of all this, wouldn't it be easier to stick a handy short piece
    of scaffold (like what I've got in my garage) through the back wheel and
    across the swing arm - with plenty of padding, of course.
    cf. removal of AndrewR's front sprocket. At least you knew not to remove
    the chain first...
    Ummm... if the threads on the nut are that fucked, then surely the
    threads on the output shaft must be equally fucked?
    Eddie, Nov 10, 2004
  3. Lozzo wrote
    because they are fucking pikeys. They haven't yet sussed out that even
    investing 30 quid in a couple of modest torque wrenches will save them a
    lifetime of expensive guesswork. That or the **** didn't give a ****
    because he would not be holding on to the bike for long and thinks the
    next owner is a muppet.
    steve auvache, Nov 10, 2004
  4. Lozzo
    Eddie says...
    Not easy, means removing the hugger, which means removing the back wheel
    then putting it all back in to remove the nut, then stripping it all out
    gain to put the hugger back afterwards, then putting the wheel back in
    again etc etc. Too much aggro when I can just wedge the front against a
    wall and lock the brake on.
    No, the shaft is a hardened gear shaft, the nut is normal mild steel.
    The nut will always stretch first. I ordered a new one and a new lock
    washer as soon as I realised the nut was tightened so badly 2 days ago.
    Lozzo, Nov 10, 2004
  5. Lozzo
    JB Guest
    Air impact wrench. Probably the same as the pikey mechanic used to put it
    on.
    JB
    JB, Nov 10, 2004
  6. Lozzo
    Champ says...
    Work it out. End of 6 foot scaffold pole lifting 185kg of bike in the
    air from about its mid point, pivoting on the front wheel before it
    cracked off. I'm crap at maths and wouldn't even have a clue where to
    start, but I'm sure the FOAK won't let us down on this one. Really, this
    was way way overtightened.
    Lozzo, Nov 10, 2004
  7. Lozzo
    mb Guest
    Some loosen up over time. When I changed the one on the GTS, I unfolded
    the locking tabs to find the 'kin thing was loose =:-O
    mb, Nov 10, 2004
  8. Lozzo
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, mb
    That'll be due to the incredible forces it experiences under braking.
    Nigel Eaton, Nov 10, 2004
  9. Lozzo
    tallbloke Guest
    Not a drama as long as it hadn't been so loose it was wearing the splines
    heavily. It can minimise wear on the sprocket if it can find its own line
    against swinging arm flex...
    tallbloke, Nov 10, 2004
  10. Lozzo
    Lozzo emerged from their own little world to say
    SNIP
    <lovingly pats shaft drive>
    wessie, Nov 10, 2004
  11. Lozzo
    mb Guest
    Heh, I'll have to change that, I never get any bites.
    http://www.mts.net/~neelin/motorcycle/biblio.html halfway down the page
    "Stop Action..."
    mb, Nov 10, 2004
  12. It was somewhere around Barstow, on the edge of the desert, when the
    I know; the cunts who do that use an air tool. Should be rammed up their
    arse, imo. Quite what it might do to the much more expensive to replace
    thread on the output shaft, I'd rather not think about.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Nov 10, 2004
  13. Lozzo
    Christofire Guest
    Having had the front sprocket come loose while riding along twisties,
    and thus depositing engine oil just in front of the rear wheel I can
    tell you it's no barrel of laughs if you under-tighten it.
    That nut got tightend to specified torque, had threadlock on it and had
    a folded washer holding it in place. That didn't do the job, so it got
    double everything next time round.
    Christofire, Nov 10, 2004
  14. Lozzo
    OH- Guest
    The most probable explanation, already suggested, has to do
    with berserk air tool use.
    On my XT, this nut would rattle loose no matter how I tried to
    get the lock tabs just right. But instead of brute force I used a
    few drops of Loktite and the problem was gone and the force
    required for loosening it is almost reasonable.
    OH-, Nov 10, 2004
  15. Lozzo
    Eddie Guest
    Ah, yes - didn't realise you had a hugger. That would get in the way
    slightly.
    Eddie, Nov 11, 2004
  16. Lozzo
    Eddie says...
    It does...lots. I've never seen a hugger that was so awkward to remove,
    there's brackets all over the place.
    Lozzo, Nov 11, 2004
  17. Lozzo
    Eddie Guest
    Odd... most of them have ~4 screws into the swingarm, and you can
    remove/refit them without removing the back wheel.
    Eddie, Nov 11, 2004
  18. Lozzo
    Eddie says...
    This has a convoluted brace that runs down the inside and along to the
    rear of the offside, to steady the bit of hugger that goes toward the
    back. It's a nice looking hugger, but the bracketry is horrible and I
    may change it for something of my own design that doesn't require the
    wheel to be removed first.
    Lozzo, Nov 11, 2004
  19. Lozzo
    Zymurgy Guest
    Lozzo wrote
    1) Take bike to local garage
    2) Take out 4 pack of beer
    3) Hand to Mechanic
    4) Mechanic uses zip gun to loosen front sprocket
    5) Tighten up sprocket with socket and breaker bar
    6) Ride gingerly home
    7) Remove sprocket with your favourite socket.
    Outlay no more than 4 quid (i.e. don't buy anything decent, it's only
    a grease monkey). No gashed knucles or broken tools/ bike.
    Job done,
    Cheers,
    Paul.
    Zymurgy, Nov 11, 2004
