front paddock stands
Discussion in 'UK Motorcycles' started by darsy, Mar 9, 2005.
  1. darsy
    <snow crash>
    I never had you down for a pizza-boy
    </sc>
    darsy, Mar 10, 2005
  2. darsy
    Verdigris says...
    I'm using a cheapo Micron stand with bobbins and hooks on the ZX9 and
    it's easy to use on my own. As you know, I'm not the biggest built
    person around. It was just as easy with the Thunderace too. There's a
    knack that helps you use as little muscle power as possible and keeps
    the bike remarkably stable during both operations.
    Lozzo, Mar 10, 2005
  3. darsy
    darsy, Mar 11, 2005
  4. darsy
    antonye Guest
    Yes - I've got the rear stand (bought at Ally Palace for
    £15) and it's no different to any other rear stand - maybe
    the metal isn't as thick, but it still works fine. These
    "new" style ones have an extra bar on the legs to help
    strengthen them. My mate Phil had the one without and
    he said it did start to weaken the join after 2 years of
    constant use, but he solved it by having the two parts
    welded together. For £18 and three years use, that's not
    bad.
    I've used this type front too, and they do work. You have
    to be very careful to get the forks onto the prongs, but
    it's stable once it's on. The ones with pegs which locate
    under the forks are better, but then you'd need specific
    widths for each bike (I think) so that's probably not ideal.
    Most tyre fitters use the prong types from what I recall.
    How many times are you really going to use a front stand
    though? The only thing you'd use it for is removing the
    front wheel to change the tyre, as you can't use these ones
    to take the forks out (and I can't see you doing that too
    often!) and I doubt you'll do that more than once a year?
    If you're doing lots of trackdays then just get it done
    there as I've not been to one yet without a tyre van on
    hand to fit tyres.
    antonye, Mar 11, 2005
  5. darsy
    Ideally, I'd /never/ use it[1]. However, my general track plan for this
    year is to put very sticky tyres on, but have a spare set of WOWs, so
    that if it rains, I can swap the wheels over and continue[2].
    Hence the need for a front track stand!
    [1] i.e. it won't rain during a trackday.
    [2] I lost at least 2 sessions at Cadwell on my TRX due to it being
    rather wet, and the bike being fitted with Michelin Pilot Race tyres,
    which are terrible in the wet.
    darsy, Mar 11, 2005
  6. darsy
    Eddie Guest
    I've got one of them, and have used it on at least 5 different bikes -
    if there's any significant difference in the distance between the forks,
    I just adjust the stand to match by pulling the ends apart or pushing
    them together.
    Eddie, Mar 11, 2005
  7. darsy
    You seem to have missed the requirement to be able to easily swap
    wheels for wet and dry conditions.
    Champ, Mar 11, 2005
  8. darsy
    antonye Guest
    Ah, ok, I didn't realise this. In that case don't worry
    about which stand to go for - just get the cheapest one
    and one of those prong ones will be fine.
    I missed a whole afternoon at Rockingham because of the
    weather - it started pissing down just as our group came
    in, and the next group was stopped for a faller. They
    stopped for lunch early because of this, then carried on
    in the afternoon. There were 13 fallers in total that
    day and at the rate they were coming off I just decided
    it wasn't worth the risk for the sake of half the £90
    I'd paid for the day.
  9. darsy
    flash Guest
    If it rains then just ride slowly and shit yourself everytime you have to
    lean it a bit.
    flash, Mar 11, 2005
  10. darsy
    So my dry-weather riding technique will work just as well in the wet?
    Result!
    ogden, Mar 11, 2005
  11. darsy
    that's not exactly a lot of fun, is it?
    darsy, Mar 11, 2005
  12. darsy
    flash Guest
    If God had meant motorcycles to be fun he'd have put roofs on them.
    flash, Mar 11, 2005
  13. darsy
    http://images.google.com/images?sourceid=navclient&ie=UTF-8&rls=GGLD,GGLD:2004-12,GGLD:en&q="BMW+c1"
    Champ, Mar 11, 2005
  14. darsy
    flash Guest
    So God rides a BMW? Cool. All it needs now is a couple more wheels.
    flash, Mar 11, 2005
  15. darsy
