Front Fork Seal Driver ?
Discussion in 'Motorbike Technical Discussion' started by Iowa883, Jan 3, 2005.
  1. OK, fair enough - never seen it done that way, and I'm not sure I'd want
    to do it that way, but yes. Apologies.
    The Older Gentleman, Jan 4, 2005
  2. I follow the manual...pretty darn simple on a GL1000.
    See the above manual reference. I'm not disagreeing with you
    and it may work for you. I just wouldn't do it that way.
    Nefarious Necrologist 42nd Degree
    Some people ride, some just like to show off their butt
    jewelry once in a while.
    Dum vivimus, vivamus
    <:(3 )3~ <:(3 )3~ <:(3 )~ <:(3 )~
    Keith Schiffner, Jan 5, 2005
  3. Iowa883
    G C Guest
    Leave the front hang over the end
    Lift bike
    remove front wheel and axle
    remove fender
    remove brake
    undo bolt at bottom of leg
    Tube stays in tree and adjustment isn't lost
    This works on my Honda and H-D, the Ducati's are a different story
    Still don't see a need for two piece driver for fork seal, however,
    other places it can come in handy.
    Gopher 33 28 19N 112 01 49W
    '77 CB750K (Street) '78 CB750K (Cafe)
    '79 FLHassle (Gone) '00 ZG1000 (Sarge)
    '97 Ducati M750 (horse with no name, yet)
    Pull 'mychain' to reply
    G C, Jan 5, 2005
  4. Iowa883
    bowman Guest
    That would be the damper tube bolt that sometimes requires an industrial
    strength impact driver? Isn't there often some kind of fluid in those
    things too? Damn complicated crap. Springers were good enough for Grampa.
    bowman, Jan 6, 2005
  5. Iowa883
    G C Guest
    Grampa don't race.
    '96 Ducati 900SS (Trackstar)
    G C, Jan 6, 2005
  6. That's what YOU think...trust me it sucks when you're out
    riding along at a nice clip at speeds that ensure chrome
    braclets and you get passed by some speed demon on GSXR1000R
    and at your next gas stop that power ranger turns out to be
    old enough to be your father. Granted a guy 58 isn't really
    all that old imo...but some of the kids here will think it's
    ancient.
    Keith Schiffner, Jan 6, 2005
  7. SNIP
    End of WHAT? End of the curb? End of the Grease pit(OF's
    know what I'm talking about)
    Yep a center stand is GREAT for that.
    I can to that with just a few bolts.
    Yep, being a late 70's UJM it's a bit more involved than
    newer bikes.
    Yep X2 for me.
    ? Have to pull the plugs at the top and the drain at the
    bottom. Pull the springs THEN undo a allen bolt at the
    BOTTOM of the fork from the inside.
    What adjustment? It always lines up just right, UNLESS your
    tubes are bent...or extended and that is just stupid.
    If it works for you great. I just always remind myself that
    no matter what something looks like if it works it's good.
    Dusted these and CBX's regularly...US89 belongs to old wings
    and modern sportbikes.
  8. Iowa883
    G C Guest
    I'm the crusty old fart passing in the corner on a 'slower' bike. I
    would probably just have to give it all to the courts on a modern liter
    bike. I like really twisty roads that the kids can't use that squirt
    power on and are forced to RIDE in the corners. ;-> I wouldn't do this
    with a girder or springer front. (unless I was wobbling on some vintage tin)
    G C, Jan 6, 2005
  9. Iowa883
    G C Guest
    Floor lift
    I'd undo the bolt at the bottom first while the spring pressure is on it
    .. Helps to keep it from spinning (internal) on you.
    Funny, but I can tell the difference of 1 or 2 mm distance of the tube
    in the trees. Extended is stupid but tubes run up a bit can really add
    some turn-in.
    They were the dawn of the superbike era, but that's why I have the Ducatis.
    '96 Ducati 900SSSP
    G C, Jan 6, 2005
  10. Iowa883
    bowman Guest
    Funny, but I can tell the difference between 1 and 2 mm on my handly little
    steel rule when I put them back in. I'd be lying through my teeth if I said
    I could detect handling differences in less than 1 inch increments.
    bowman, Jan 7, 2005
  11. SNIP
    Still you got my point eh? 8^) I tend to usually not get
    lost by newer bikes in the twisty stuff, but then there's a
    straight bit and...well Honda claimed a 80Hp @ 7,000rpm and
    you know that was optomistic. 25 years and no rebuilds and
    it STILL hauls butt!
    You do realize that none of your bikes are slower (stock)
    than mine. ;^) But I LIKE my 79' GL1000, might have to put
    some MX bars on it to spice up the handling in the twisty
    stuff.
    79' Gl1000 (OG) 'cause his knuckles drag and he's simple
    minded.
    Keith Schiffner, Jan 7, 2005
  12. SNIP
    Stand what's that? Heck where I live these days I don't even
    have a garage and being montana I have to do all work
    quickly. It's about time for new front springs anyway.
    GAH! Forgot the bolt head IS external...why as a matter of
    fact I do read over the manual on occasion. Just for fun,
    HONEST!
    I'll keep it in mind.
    SNIP
    8^)
  13. Iowa883
    G C Guest
    Oh yeah, I had a '75 wing that even had a kicker hiding under a cover.
    Stripped off every single thing that didn't make it go. Was a fun cafe
    bike and really fooled a bunch of folks. They go well with 100 pounds of
    chrome and fenders and lights and other odd bits removed.
    G C, Jan 7, 2005
  14. Iowa883
    G C Guest
    Try riding on the track instead of the street. Little changes can mean a
    lot. (Especially when we are trying to pare off tenths each lap)
    G C, Jan 7, 2005
  15. Iowa883
    Bruce Farley Guest
    On the newer "upsidedowm" style forks the only way to remove the seal
    driver is for it to be split. The fork tube that the seal get fitted
    into is held in the t stem and the tubes on the lower part end with the
    axle mounts. The seal is installed upside down and if the seal driver
    were on the tube below the seal it cold not be sliped off the tube as is
    done with conventional forks. The driver must be removed by being able
    to split in 2 parts.
    Bruce
    Bruce Farley, Jan 9, 2005
  16. Iowa883
    Iowa883 Guest
    Bruce,
    Thanks for the info. I am going to do a set of forks on a YZ85 with upside
    down forks. I will see what I run into.
    I can't picture it but I will find out.
    Thanks,
    Iowa883
    Iowa883, Jan 11, 2005
