Front cylinder cuts out after running
Discussion in 'Motorbike Technical Discussion' started by Michael, Jul 21, 2003.
  1. Michael
    Michael Guest
    Looking to see if anyone has any idea what is going on here.
    Generally my bike starts up fine (it's a yamaha 84 virago 700) And you
    can tell it's running fine on both cylinders by the way it starts,
    plus it's piped, so you can hear it. After a while of running the
    front cylinder will cut out, if i stop, shut it down and let it sit
    for a minute usually it will start up on both cylinders again. I
    pulled the plug and it hasn't fouled at all, and the rear cylinder
    always runs well. What could cause it to cut out like that. Is
    something clogging the carbs just enough that the front cylinder isn't
    getting enough gas at high rpm's? Doesn't make any sense to me, in
    any case usually once it's been running a while it stays running, and
    i don't have any more problems till i stop for a day. Any ideas are
    very welcome, thanks for any input.
  2. Michael
    SL Guest
    Had a similar intermittant problem with my ol' Kawi - - coil wire/cap at
    the coil-end was iffy. One coil runs two cylinders (in-line 4), so I'd
    lose my inner two... When the bike completely heated up (like 20 miles
    from anywhere), the wire/cap expanded and lost electrical contact.
    Drove me crazy after the compression test (in-line 4 again, and of
    course it was the inner cylinders), spark test, coil test, etc. Check
    the coil cap(s) at the coil-end, even if your bike shares a coil for the
    two cylinders (geez - - blonde moment - - a 700 Virago is a twin,
    right?). Repeated tightening finally *quit solving* the problem
    temporarily, but a new coil wire assy. fixed it.
    SL, Jul 23, 2003
