I have a technical front brake question. My '88 NX650 front brake seems to be grabbing and releasing with every revolution. I've replaced the disc and shimmed to try and get any wobble out of it but it still seems to be having trouble. Unfortunately I thought it was the rotor and purchased a new one about a year ago. With the new rotor installed the problem is still there. So the problem is the hub? And the problem is not a pulsating brake lever, instead it is a diving up and down front end as I apply the front brake gradually. The use of shims has helped minimize the diving up and down but not eliminated it. There are 2 pins or actually two bolts going through the caliper and bolting to the front fork. Ideally the caliper has some self-centering freedom on those bolts. So I was thinking how could the cast hub be bent without breaking. If some manufacturing variance is expected in the cast hub (maybe 1/1000 or 2/1000 of an inch), then maybe that variance is expected to be compensated by the front brake caliper being allowed to float. If my 1988 caliper bolts have worn and now have a groove in them where the caliper normally rests, then that groove would be limiting the movement of the caliper and limiting the forgiveness for the imperfect hub/disc. Does any of this make sense or sound probable? Has anyone else experienced/fixed this? Wayne
