Front brake 'pulsing'
Discussion in 'UK Motorcycles' started by Ben, Apr 15, 2011.
  1. Ben
    Ben Guest
    Champ's post about his car brakes reminded me of something, when I
    brake hard on the GSXR, I get a kind of 'pulsing' from the front. At
    it's most extreme when braking very hard it feels like the front wheel
    is juddering off the road. I've had a good look over and can't see
    anything loose or wrong looking. Spinning the wheel the discs appear
    to run true.
    Any ideas? Maybe I should get it into the men who know prior to my
    Silverstone trackday.
    Ben, Apr 15, 2011
  2. Ben
    Get a rag with brake cleaner on it and clean your discs down. Might
    just be a build up of brake dust on the discs themselves.
    Lozzo
    they churn out)
    Lozzo, Apr 15, 2011
  3. Ben
    TOG@Toil Guest
    What he said.
    TOG@Toil, Apr 15, 2011
  4. Ben
    Thirded.
    Krusty, Apr 15, 2011
  5. And if that doesn't work you can check them quite simply by taping or
    elastic banding a biro to the fork leg with the end just quite not
    touching the disc, then spinning the wheel to see if the gap changes
    at all.
    Brownz (via Gurgle Gruppez), Apr 15, 2011
  6. Ben
    completely different bike, but when I (waaay back in December 2002)
    collected the R65 from WUN, it felt like what you described. Just
    cleaning the discs (with Fuxitorf, IIRC) and riding and braking like a
    twat sorted it out. The problem just "went away".
    darsy, Apr 15, 2011
  7. Ben
    Mark Olson Guest
    I've seen it many times where you'd swear the disks were warped but it
    was something embedded in the disks and a few minutes rubbing them down
    with coarse sandpaper while spinning the wheel sorted it out. You can
    get as fancy as you like, clamping the sandpaper between two pieces of
    lath, or whatever, but I simply used my fingers and nobody died.
    Mark Olson, Apr 15, 2011
  8. Ben
    crn Guest
    Very often caused by material transfer from the pads to the disk which
    is usually mis-diagnosed as a warped disk.
    This is caused by clamping the brakes onto a very hot disk.
    When coming to a stop from high speed or other heavy braking always
    release the brake as soon as you come to a stop and preferably
    take a gentle pootle to cool the disks.
    This generally happens when the disk is very hot, the transferred
    material migrates into the disk surface and can only be removed
    by slightly skimming the disk.
    crn, Apr 15, 2011
  9. Ben
    TMack Guest
    If its a floating disc then its also worth checking that the bobbins
    aren't seized. You should be able to turn them by gripping between finger
    and thumb on either side and twisting or by inserting a flat-bladed
    screwdriver in the bobbin hole so that it tightens on the taper of the
    blade then turning the screwdriver. If any bobbins appear seized then you
    need to free them off. A drop of WD40 or penetrating fluid will usually do
    the trick but you will need to scrupulously clean the disc afterwards so
    its best to remove the disc before you start.
    If disc cleaning doesn't work and there is no evidence of disc warping
    the check your head bearings.
    TMack, Apr 15, 2011
  10. Ben
    Nige Guest
    Or doing as Loz says or using a bit of emery paper you fucking twat.
    Nige, Apr 15, 2011
  11. Ben
    Ben Guest
    I have some brake cleaner so will give that a go.
    Ben, Apr 15, 2011
  12. Ben
    Ben Guest
    Hmm, I've tried riding like a twat and that makes the problem appear.
    Riding like a granny, it doesn't show up.
    Ben, Apr 15, 2011
  13. Ben
    try "cleaning" the disks with a bit of emery paper[1] anyway and see
    how you get on - I really doubt you've actually got warped disks if
    the effect doesn't manifest at slow speeds.
    [1] or, as I once did, try using sugar soap and a "green" kitchen
    scouring cloth - worked a treat that did, on similar (though I think
    milder) symptoms on my old TRX.
    darsy, Apr 15, 2011
  14. Ben
    Beav Guest
    That's exactly what it was with my Zed, a build up of crap, but not brake
    dust, it was the crap that the discs were coated with from the - after
    market - factory. (Black to make them look "cool") I also took the pads out
    too and gave them a few seconds abuse with a sheet of 320grip paper and for
    my troubles I was rewarded with instant pulse free braking and a better
    initial feel too.
    Beav, Apr 15, 2011
  15. Ben
    Beav Guest
    message
    Or you could get a dial gauge and know how much they're warped by if they
    *are* warped.
    I think the brake cleaning thing is the best route to take though.
    Beav, Apr 15, 2011
  16. Ben
    Nige Guest
    Mine started doing it Sunday, after a quick run, i let them cool & got the
    brake cleaner out, the muck & shit that came off was unreal.
    Gave them a light rub over with some wet & dry, took it out & it was fine.
    Nige
    Nige, Apr 19, 2011
  17. Take it to a bike shop with a dial gauge. It could be a warped disk.
    Not a big job to check.
    Fraser
    Fraser Johnston, Apr 19, 2011
  18. Ben
    Ben Guest
    I gave the discs a good scrubbing down with brake cleaner on Sunday
    and took it out for a thrash. Still happens when braking really hard,
    but not as much as before. It's a bit like the pads grip, then slip,
    then grip, then slip.
    I'll scrub them a bit more this weekend.
    Didn't take the pads out because they're radial calipers and I
    couldn't for the life of me work out how to get them out without
    actually taking the calipers off the fork legs, which seemed a little
    odd. Will do some googling on that.
    But first I've got to take the centre console out of my Focus to fix
    an electrical gremlin which is turning the stereo off.
    Ben, Apr 19, 2011
  19. My 07 GSX-R 1000 was bought as a wreck and it had a bent disk even
    though it was unmarked. Might be soft disk material that caused it.
    Pulling the calipers off isn't a big job only 2 bolts per side. Just
    don't attempt it on a ZX-10R where the caliper bolts are made of silver
    cheese.
    Fraser
    Fraser Johnston, Apr 20, 2011
  20. Ben
    I've had the same ZX10R caliper bolts on and off my mate's race bike
    about 5 times every weekend we raced, which was once a month, for four
    years and never chewed one of them. Buy decent tools
    Lozzo
    they churn out)
    Lozzo, Apr 20, 2011
