front brake light switch: troubleshoot?
Discussion in 'Motorbike Technical Discussion' started by Brent, Jul 26, 2004.
  1. Brent
    Brent Guest
    Planning to help a buddy fix his front brake light switch on his '83 Shadow
    tonight. Rear brake light switch works fine; but the front one doesn't
    trigger the taillight. Wiring and terminals at front switch plug-in look ok
    (cleaned and di-electric greased).
    I'm thinking that someone may have a couple of good clues to check, rather
    than the usual marathon continuity check.
    Anyone?
    thanks
    brent
    Brent, Jul 26, 2004
  2. Brent
    Cees Keyer Guest
    MOst of the time the switch it self is broken, check with a VOM.
    or short circuit the terminals to check the wiring.
    In the time when i was riding a Honda 3 years i had to replace the front
    brake switch twice.
    Good luck
    Cees
    Cees Keyer, Jul 26, 2004
  3. Brent
    Mark Olson Guest
    Does the brake light come on if you disconnect the two wires from the
    switch and short them together? If so, the switch is bad, otherwise
    it is an open circuit somewhere in the wiring.
    If it's not the switch, it is most likely due to a corroded bullet
    connector, but it could also be a severed wire, look for places where
    the wiring harness has chafed through its protective covering.
    Mark Olson, Jul 26, 2004
