French Run ferry details
Discussion in 'UK Motorcycles' started by Colin Irvine, Mar 30, 2011.
  1. Colin Irvine
    Colin Irvine Guest
    These have now been circulated to those taking the Dover ferry.
  2. Colin Irvine
    Simon Wilson Guest
    When is it? etc.
    Simon Wilson, Mar 30, 2011
  3. Colin Irvine
    Am I booked into this weekend?
    Hog, Mar 30, 2011
  4. Colin Irvine
    Pete Fisher Guest
    My filed folder claims I sent my reg no. on 12 March. Just resent so
    hopefully you have just got it now.
    | Pete Fisher at Home: |
    Pete Fisher, Mar 30, 2011
  5. Colin Irvine
    Colin Irvine Guest
    You did and I did. Both times!
  6. Using the patented Mavis Beacon "Hunt&Peck" Technique, Colin Irvine
    Where are we going?
    Wicked Uncle Nigel, Mar 30, 2011
  7. Colin Irvine
    I think it's Spain. I hope it's Spain.
    ogden, Mar 30, 2011
  8. Colin Irvine
    <reeky>
    Nah, it'll be somewhere in Europe.
    </r>
    Krusty, Mar 30, 2011
  9. Colin Irvine
    It'll rain on the way home
    Hog, Mar 30, 2011
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, ogden
    Oh, I hope not. You need a passport for Spain, don't you?
  11. Colin Irvine
    Jeremy Guest
    Yes but I think the petrol stations are usually open on Sundays there.
    Jeremy, Mar 30, 2011
  12. Colin Irvine
    Nige Guest
    Am i going?
    Nige, Mar 30, 2011
  13. Colin Irvine
    You're on the other boat.
    ogden, Mar 30, 2011
  14. Colin Irvine
    SIRPip Guest
    Can I change my bike details?
    SIRPip, Mar 30, 2011
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, SIRPip
    You're taking the Ural?
  16. Colin Irvine
    Stephen Guest
    Wearing comfortable shoes?
    Stephen, Mar 30, 2011
  17. And speed limits don't apply on weekends.
    Speedgazebo MOTP #1, Mar 30, 2011
  18. Colin Irvine
    zymurgy Guest
    Someone will break down before the ferry
    Someone may not make it off the ferry
    Someones luggage will end up on the M20 or in a Fireball.
    Someone will be a petrol muppet
    Someone will get lost (usually me)
    Paul.
    zymurgy, Mar 30, 2011
  19. Colin Irvine
    SIRPip Guest
    Might be. Do you think that'll be OK on the ferry?
    Anyway - I may have got to the bottom of the bizarre running problems -
    it appears to have been in the process of destroying a throttle cable.
    Those things don't just die overnight, right? Anyway, the RH one
    finally pulled out of the twistgrip linkage and in the process of the
    PM, it turned out to have a stray strand, which had been sticking into
    the liner of the outer, causing an intermittent jam.
    So, If I'm giving it WFO, but only the left carb is actually WFO and
    the right carb is just off tickover then strange things are going to
    happen. It obviously isn't going to pull properly and perhaps the
    occasional surging may be explained too. Then there was the backiring
    and ultimately the furnace in the silencer.
    It was also fitted with two equal length cables, whereas the right one
    should have been shorter - being too long, it will have been bent
    around more than intended, which has probably caused the premature
    wear. So a new throttle linkage is on order, with a cable kit: nobody
    has cables available as made up units, so it's a length of outer, a
    length of inner, a bunch of ferrules and solder your own nipples.
    The nipple soldering might be a challenge, as the cable is 1.7mm and
    the OD of the nipple only 3.0mm. Not much room for Mr Blobby.
  20. Using the patented Mavis Beacon "Hunt&Peck" Technique, SIRPip
    Oh yeah, we'll just form up in a group around you and smuggle you on.
    What could possible go wrong?
    Hmmm... If any modifications are required, give me a shout.
    Wicked Uncle Nigel, Mar 31, 2011
