freeing a rusted piston
Discussion in 'Motorbike Technical Discussion' started by Dick Johnson, Aug 5, 2004.
  1. Dick Johnson
    Dick Johnson Guest
    What can I use to free a small piston whose steel rings have rusted to
    the sides of an aluminum head?
    I have applied a penetrant like WD40 and will repeat for several days.
    I plan to use a propane torch to expand the walls a bit to try and
    break it free.
    Has someone had success with a similar problem?
  2. Dick Johnson
    Popeye Guest
    Diesell fuel, or automatic transmission fluid are both pretty good at
    wicking into a frozen cylinder. Soak for a day or 2 then gentle
    tapping on top of piston with a block of soft wood and a hammer.
    Brian
    Popeye, Aug 5, 2004
  3. Dick Johnson
    Dick Johnson Guest
    ATF sounds like a good idea. I finally freed the piston, using Rick's
    suggestion of a PVC pipe as a rammer.
    My thanks to Brian and Rick for the input.
    Dick Johnson, Aug 6, 2004
  4. Dick Johnson
    Dick Johnson Guest
  5. Dick Johnson
    Dick Johnson Guest
