frankfurt challenge redux
Discussion in 'UK Motorcycles' started by darsy, Nov 13, 2003.
  1. darsy
    Ben Blaney Guest
    You're a lovely feller.
    Ben Blaney, Nov 16, 2003
  2. <VVBG>
    I might use that some time.....
    The Older Gentleman, Nov 16, 2003
  3. darsy
    Best Western looks OK.
    Anyway, I've just "endurance tested" the CD - 80 mile round trip to
    your place/leisure centre - absoluetly faultless performance.
    darsy, Nov 16, 2003
  4. Champ said:
    Sounds like a series Land-Rover he was describing.
    Simon Atkinson, Nov 16, 2003
  5. darsy
    PeterT Guest
    Timo Geusch
    S'wat I thought. But it's close to the red light district.
    PeterT, Nov 16, 2003
  6. darsy
    PeterT Guest
    The Older Gentleman
    It is indeed! Which reminds me to ask. With it's MOT is it legal to
    separate the combo and ride the bike, assuming you fix a signal light
    to the left hand side?
  7. darsy
    PeterT Guest
    sweller
    Good call!
  8. PeterT said:
    It would be intersting - the frame usually takes a bit of a 'set' with a
    chair fitted and can make for intersting handling when it's removed...
  9. darsy
    Ben Blaney Guest
    Good-oh. I'm pretty sure that mine will be okay. The clutch is
    slipping a bit though - what causes that? Should I get it sorted before
    the run?
  10. darsy
    mups Guest
    Fucked clutch plates, knackered springs, engine producing too much power[1]
    Yep.
    [1] Yea right
    mups, Nov 16, 2003
  11. darsy
    mine does too, if you let the clutch out too slowly - it never slips
    when you haven't been near the clutch i.e. just under acceleration.
    depends on how bad it is.
    darsy, Nov 16, 2003
  12. darsy
    Salad Dodger Guest
    Overtight cable?
    From experience:
    sticky slave cylinder; notched lifter mechanism; dirt in the fluid;
    blocked return hole in reservoir; loose slave cylinder.
    None of which are likely to apply to the Seedy.
    Salad Dodger, Nov 16, 2003
  13. On a Benly, it's more likely to be a knackered (ie: sticking) cable or
    badly adjusted clutch.
  14. I *think* so but wibbleflip.
  15. Die Toten Hosen? KMFDM? Rammstein? Helloween?
    Darren Robinson, Nov 16, 2003
  16. darsy
    bizarrely, for a list of bands from *you*, I actually have a recording
    by one of the above artists...
    darsy, Nov 16, 2003
  17. darsy
    PeterT Guest
    Simon Atkinson
    Well it didn't make much of a difference when I tried it, but then the
    Jawa doesn't really come with great handling anyway. Next spring I will
    give it a good overhaul. Found a place I can get the frame coated and
    am thinking of a new colour too.
  18. darsy
    PeterT Guest
    The Older Gentleman
    "Sprechen Sie deutsch?" May be the solution.
  19. darsy
    Feldgrau?
    Pip, Nov 16, 2003
  20. darsy
    Three of those are practically chart music, ffs.
    Not the Top 40 chart, mind.
    ogden, Nov 16, 2003
