frankfurt challenge redux
Discussion in 'UK Motorcycles' started by darsy, Nov 13, 2003.
  1. darsy
    deadmail Guest
    I had a lot of fun on an RD200 one summer (1981 IIRC).
    They were light, fast and handled well. OK, they were 50cc smaller than
    the 250s but the lack of weight helped a lot.
    The engines were (IME) pigs to work on because of the way that the
    crankcases split (vertical 'joint' between cases rather than
    horizontal).
    So, if I was in the market for a small two stroke[1] I think I'd go for
    the RD250 or 350 and not the 200. I had a great summer and have a good
    memory (which ended with the bike gearbox dying and never running right
    again). I'd hate to take on a bike that's nothing but trouble now and
    compromise the memory.
    I also had good times on an RD350B but I think that's more likely to
    live these days.
    [1] I think Frankfurt is a job for a honda fourstroke of some kind.
    deadmail, Nov 17, 2003
  2. darsy
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    That's Dastardly, Dick.
    Nigel Eaton, Nov 17, 2003
  3. darsy
    said....
    <points at CB250RS in sig>
    Yep
    Lozzo
    ZZR1100D, GPZ500S, CB250RS x3
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, KoBV#3.
    http://www.glfuk.com/ for MJK Leathers in the UK.
    Lozzo, Nov 17, 2003
  4. darsy
    Platypus Guest
    Campaign for Real URLs.
    Platypus - Faster Than Champ
    VN800 Drifter, R80RT, Z200
    DIAABTCOD#2 GPOTHUF#19
    BOTAFOS#6 BOTAFOT#89 FTB#11
    BOB#1 SBS#35 ANORAK#18 TWA#15
    Platypus, Nov 17, 2003
  5. darsy
    Platypus Guest
    That won't be a problem. Most of us are rough numbers.
  6. darsy
    Platypus Guest
    GWS.
    Platypus, Nov 18, 2003
  7. darsy
    Except the CB250 is too big and too suitable. Making an RD200 *the*
    ideal choice.
    sweller, Nov 18, 2003
  8. darsy
    Well yes that's true, but why no tinyurl?
  9. darsy
    Ben Blaney Guest
    Because if the wankers can be persuaded away from Outlook Express, or
    whatever other shite they use, there's no need for tinyurl.
    Ben Blaney, Nov 18, 2003
  10. darsy
    darsy, Nov 18, 2003
  11. darsy
    PeterT Guest
    Champ
    Always!
    PeterT, Nov 18, 2003
  12. darsy
    I see the .com where you've cropped it, but why there? What details have
    you chopped. I also see that the thread view has gone etc. etc.
  13. darsy
    Eddie Guest
    That's enough Slag, Brothers!
    Eddie, Nov 18, 2003
  14. darsy
    Check out the new sig!
    Champ, Nov 18, 2003
  15. darsy
    I posted a URL directly to the messageID in question, rather than to
    the pointer in the thread that was generated from a particular search.
    Actually, if I'd left off the http:// and just started with www it
    wouldn't have wrapped at all. You can get back to the thread in
    question from a single click from the link I posted.
    You can do this with any google reference. Similarly, Amazon URLs can
    be fair drastically shortened if you know how. eBay ones, I don't know
    about, but I'm sure something can be done.
    darsy, Nov 18, 2003
  16. darsy
    The 'selm' is the identifier for the article in the database. Anything
    else is window dressing and can safely be dropped.
    ogden, Nov 18, 2003
  17. ebay ones are easy, but not much can be removed. For example, this item
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=2442669236&category=30220
    can be referenced with
    which should only wrap if you're on some godforsaken 40 column
    mode teletype thing.
    William Grainger, Nov 18, 2003
  18. darsy
    mups Guest
    mups, Nov 18, 2003
  19. darsy
    simonk Guest
    Cool, ta. Popped along this morning for a look-see. Sounds OK (i.e. not
    like a bag of spanners), though it's not been run for a bit, so some of the
    control cables are a bit stiff, and the rear disc has a touch of surface
    rust.
    I'll probably go back on Thursday and take it for a spin.
    Tyres are scarily skinny, mind ...
    simonk, Nov 18, 2003
  20. darsy
    mups Guest
    The RD200 has a rear disk? Coo that's posh.
    mups, Nov 18, 2003
