Frame repair
Discussion in 'UK Motorcycles' started by Chris, Jun 10, 2004.
  1. Chris
    Chris Guest
    Hi, I would really appreciate some advice about getting my frame
    repaired (if it can be done at all).
    I have a gixxer 750 and have had an impact on the front. I've gone and
    bent the forks (which have pushed back into the radiator), snapped the
    steering lock off the bottom yoke, and on closer inspection of the
    head stock have compressed the frame.
    The frame is bent on both sides, down by the air intake holes.
    Somebody was recently selling a frame on ebay, and the damage is
    almost identical to my frame, please see:
    http://www.monsterserve.net/frame.jpg
    I have spoken to one person, he mentioned that the bike gets put in a
    jig and it gets manipulated back into place. He mentioned that the
    dents by the headstock can be popped out… is this true?
    I have pretty much demolished the tank where I hit it with me nads,
    now there is about a 10mm gap between the frame/seat and the tank
    (there never was one before the crash), and where the fuel tank bolts
    into the frame at the top it is another 10mm short.
    If I were to get a new tank after the frame is straightened how likely
    is it would line up with the mounting points (I guess i'm asking how
    accurate is frame straightening)?
    If it is possible to get sorted, can anyone recommend a frame
    repairer?
    Thanks in advance, any help is really appreciated.
    Chris, Jun 10, 2004
  2. <snip>
    That is well fucked. It's new frame time. As for your mate saying dents
    by the headstock can be "popped out" - he's talking out of his arse.
    The Older Gentleman, Jun 10, 2004
  3. Chris
    AJ Guest
    As they say FUBAR! Get your self to Spondon and pay out like a good boy
    AJ
    AJ, Jun 10, 2004
  4. Chris
    Lozzo, Jun 10, 2004
  5. <snip>
    I'm at the giggling stage now - I reckon every ukrm-er is going to click
    the link, and say: "That's fucked" as well.
  6. Chris
    Stonge Guest
    It all comes down to whether you'd trust the beast ever again with your
    life!
    I know I wouldn't!
    Stonge
    Stonge, Jun 10, 2004
  7. Chris
    <snip>
    the link, and say: "That's fucked" as well.[/QUOTE]
    That's fucked.
    Pip Luscher, Jun 10, 2004
  8. Chris
    A.Lee Guest
    Aluminium frame - then no chance to repair impact damage.
    Steel frame - so long as the damage isnt too severe, then it is possible
    to repair it,though if the tubes are dented/warped out of shape,it cannot
    be reliably fixed.
    Alan.
    A.Lee, Jun 10, 2004
  9. (The Older Gentleman) burbled:
    Even someone as mechanically numptastic as me can only concur. Scrap
    metal.
    Darren Robinson, Jun 10, 2004
  10. Chris
    Bollocks. Stick a bit of steel bar through the headstock, get a mate to
    heat it up with a blow-lamp, and pull it around till it looks straight. If
    you see any creases or wrinkles in the metal, just dress them flat with a
    ball pien hammer. It's an easy fix because aluminium softens at a
    relatively low temperature, and the heating and flexing will actually make
    the frame stronger (work hardening).
    platypus, Jun 11, 2004
  11. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember (Chris) saying
    something like:
    Nobody is going to straighten that.
    "Fucked, mate."
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Jun 11, 2004
  12. Chris
    A.Lee Guest
    Thats bollocks.Ally doesnt work harden twice, it just breaks.
    What does the blow lamp do then? Ally isnt like ferrous metals, the atomic
    bonding is completely different with larger crystals, making it far easier
    to break when manipulating it.Even getting it up to 500deg. cent.(it'll
    melt at ~630) will not make it safe to bend it - you'll just be breaking
    the crystals,so it may look OK on the surface, but it'll have lost a lot
    of strength.
    Alan.
    A.Lee, Jun 11, 2004
  13. Chris
    Oldbloke Guest
    ROFLMAO
    Dan L (Oldbloke)
    My Bike 2000 Honda CB500
    M'boy's Bike 1990 Suzuki TS50X (Heavily fortified)
    BOTAFOT #140, DIAABTCOD #26
    Oldbloke, Jun 11, 2004
