Frame paint removal
Discussion in 'Classic Motorbikes' started by Biker2 \(Threadstopper\), Jan 7, 2005.
  1. Biker2 \(Threadstopper\)
    Dan L says...
    That grease nipple is of no use if the bolts holding the damper assembly
    to the bulkhead shear, that's what happened to mine. I welded the damper
    box to the bulkhead after replacing the bolts, I wasn't taking any
    chances.
    Lozzo, Jan 19, 2005
  2. Biker2 \(Threadstopper\)
    Up until now, I'd always assumed that "trunnion" was a made up word.
    Champ, Jan 19, 2005
  3. Biker2 \(Threadstopper\)
    Champ says...
    If you'd ever owned a Moggy Minor you'd wish it was.
    I had another problem with mine, in that the brake and clutch pedal
    pivot on the same shaft which runs under the floor, which is also where
    the brake master cylinder is. After a few years the shaft gets gummed up
    with old grease and shit, so every time you apply the brakes the clutch
    starts to disengage and when you depress the clutch the brakes slow the
    car down and the brake lights come on. If you can learn to drive in a
    car that does that then you deserve a full licence.
    Lozzo, Jan 19, 2005
  4. Biker2 \(Threadstopper\)
    Any BMC era car seemed to have them. My Leyland van has them too. I
    believe the old Sherpas were based on the then existing Cambridge running
    gear.
    Yeah, but they're a piece of piss to sort. You could still get the
    little wooden bearings - off the shelf - when I last wanted one.
    Two of my old Morrises needed a quick tap on the brake pedal to rebuild
    the brake pressure before making a proper application. Follow a
    knackered Morris and watch the brake lights flash momentarily before they
    come on properly....
    sweller, Jan 19, 2005
  5. Biker2 \(Threadstopper\)
    sweller says...
    Horrible design, even if it did work quite well. They were fitted to the
    Moggy Minor because they took up very little space. IIRC Sir Alec
    Issigonis designed the engine bay and front suspension to accomodate a
    flat 4 engine. As a cost cuting measure they went with the old sidevalve
    Morris 8 engine that was already in production.
    I never got round to fixing it. I wrote the car off three weeks after
    passing my test.
    That was normal on just about every BMC/Leyland car I've ever owned.
    Lozzo, Jan 19, 2005
  6. It was somewhere around Barstow, on the edge of the desert, when the
    The trunnion design was just plain crap. The slightest road grit getting
    underneath the woefully inadequate rubber seal and the grease turned
    into a very effective grinding paste on the trunnion threads.
    Luckily, none that I know off ever sheared in a straight-ahead position,
    they all happened at parking angles.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Jan 19, 2005
  7. Biker2 \(Threadstopper\)
    Ooh, well done! I think it took me 5 or 6 weeks.
    Champ, Jan 20, 2005
  8. Biker2 \(Threadstopper\)
    Dan L Guest
    Crikey, that's certainly a new take on MM trunnion failure.
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R
    Spare Bike 1990 Suzuki TS50X
    BOTAFOT #140, DIAABTCOD #26, BOMB#18 (slow)
    Dan L, Jan 20, 2005
  9. Biker2 \(Threadstopper\)
    Dan L Guest
    Dan L (Oldbloke)
    Dan L, Jan 20, 2005
  10. It was somewhere around Barstow, on the edge of the desert, when the
    Just wtf were you stripping?
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Jan 26, 2005
