Can anyone advise me of the location of the frame and engine numbers on a Yamaha Thundercat? I'm going to look at one tomorrow and would prefer to know where to look rather than have to hunt for them if the owners manual isn't available to point me in the right direction. -- Alex SRX 400 "I laugh in the face of danger" "Then I hide until it goes away" www.drzoidberg.co.uk
FFS. Look first for the frame number to be stamped on the headstock, and the engine number to be stamped somewhere on the crankcase. When you find out exactly where the numbers are, would you be so kind as to let the group know where you found them? Ta.
ITYF that's rarely the case, all the bikes I've owned (2 from new) have had different engine and chassis numbers.
Yes, Ginge. That'll be one number on the headstock (the frame or chassis number) and the other on the crankcase (the engine number). IME that's where they'll be - the engine number commonly stamped into a raised plinth above and beyond the clutch cover.
You could try googling for Mike Buckley's email (he's posted on here within the last week IIRC) and see if he knows.
Thanks all. I only asked because the only time I've had cause to look for them in the past was on my SRX and as thats an unfaired bike they were fairly easy to spot. Where most of the bike is buried under a load of plastic I thought they may be in different places that would make them easier to spot IYSWIM -- Alex SRX 400 "I laugh in the face of danger" "Then I hide until it goes away" www.drzoidberg.co.uk
Dr Ivan D. Reid wrote: Ta. -- Alex SRX 400 "I laugh in the face of danger" "Then I hide until it goes away" www.drzoidberg.co.uk
Although I have a bike where the frame number is on a frame rail at the back under the seat. Which is the first place the MOT chap and I thought of looking.
Headstock for the frame number but can't remember where the engine number is (though the suggestions on here are probably accurate). Don't have the Cat any more (*sob*) so can't check. The Cat MSN group is pretty useful: http://groups.msn.com/YamahaThundercats
